220CNC TEA/Trick Flows :)** Dyno sheet RESULTS**
Old 03-26-2012, 01:39 PM
lt4388stroker's Avatar
Default 220CNC TEA/Trick Flows :)** Dyno sheet RESULTS**
Got my Trick Flow heads in a couple days ago thought I would share some pics
Only thing i am swapping out the old stuff for is lt4 heads, lt4 intake and 42lb injector swap
Trick Flow/TEA 220CNC
Flow Chart
Lift Intake Exhaust
0.100 69 54
0.200 146 129
0.300 212 186
0.400 259 226
0.500 292 247
0.550 302 255
0.600 303 260
0.650 306 266
0.700 308 271
Old 03-26-2012, 02:39 PM
3DFORMULA's Avatar
Nice flow numbers What size shot do you use for the sig. numbers?
Old 03-26-2012, 02:43 PM
Puck's Avatar
TEA makes a badass head, do you know what cam you'll be using yet?
Old 03-26-2012, 02:44 PM
lethal bird's Avatar
Do want!
Green3spd's Avatar
Very nice
Old 03-26-2012, 02:49 PM
AChotrod's Avatar
Sexy time!!!
Old 03-26-2012, 03:05 PM
thanks fellas, to answer the 2 questions
1. numbers in the sig are on mildy ported gm heads and off a 150 shot.
will now be running a 175 shot
2. still using my same cam its comp cam 230/236 113. so its a 59x lift with 1:6's
only thing im doing is alt4 head swap lt4 intake and 42lb injectors is all.
Old 03-26-2012, 03:16 PM
draggin97s10's Avatar
if you're on stock heads now...i say it will pick up quiet a bit.
Old 03-26-2012, 03:36 PM
Thats what im hoping for haha, they were stock hand ported so they didnt do to bad for what they were can't complain
Old 03-26-2012, 06:42 PM
Rob94hawk's Avatar
Nice! What valves and springs are attatched to the heads?
Old 03-26-2012, 06:48 PM
Sc0tt30's Avatar
Very nice!
Old 03-26-2012, 07:05 PM
2.055" and 1.600" Ferrea valves, as for the springs,
they are standard 23 degree spring package that TEA offers
.650" lift and will
yield 140# seat and 380 or so open.
Thanks Scott
Old 03-26-2012, 07:23 PM
SPOOLED UP's Avatar
very nice
Old 03-26-2012, 07:27 PM
ZO7 Josh's Avatar
How Much????
Old 03-26-2012, 07:35 PM
Originally Posted by ZO7 Josh
How Much????
want the link haha.. 2 grand
Old 03-26-2012, 09:24 PM
flyinZ's Avatar
Looks good! Those heads were my 2nd choice for cylinder heads.
Old 03-26-2012, 10:00 PM
yea I looked several heads but i found these had the best flowing numbers so i decided on these hopefully they will do good
Old 03-27-2012, 12:18 AM
ZO7 Josh's Avatar
Thank you!!
Old 03-27-2012, 09:41 AM
Thank you!!
Np
Old 03-27-2012, 11:43 AM
RealQuick's Avatar
Nice numbers, but the exhaust numbers are super high...
At .500 lift your heads flow 300/243
Some examples of other popular LTx stuff:
AI CNC TFS at .500 flow 285/196 (AI website)
LE TFS at .500 flow 285/197 (on a recent customer's heads)
AFR 227's with race port at .500 flow 288/208 (my heads)
Quick Reply: 220CNC TEA/Trick Flows :)** Dyno sheet RESULTS**
