lt1 info needed
Old Apr 29, 2012 | 06:29 PM
oregon93z28's Avatar
Default lt1 info needed
Hello guys, pretty new to the ltx motor. I am planning a cam swap for my 93 a4 z28 soon and this is my list of parts:
Cc503 cam
1.6 rrs
Alex spring lt1 springs
New msd opti
Pnp on the heads an intake
taylor wires
Mail order tune
My question is do I need different injectors, if so what size brand? Is a 3600 stall overkill? Anythink else I should get or change while I'm there?
Old Apr 29, 2012 | 07:37 PM
F0x Slaughter's Avatar
Lots of guys run the 503 on stock injectors. You can run a 226/232 AI cam with stock injectors.
Old Apr 29, 2012 | 07:47 PM
93 LT1 Vette's Avatar
I'm running almost the same cam on stock (new) 22lbs injectors. No problems with suppling fuel, even with a .035 fuel jet for a 150 wet shot.
Old Apr 29, 2012 | 07:50 PM
The 503 is a bigger cam then you're running.
I think you're injectors are to small for your setup. Have you ever put a wideband on it?
Old Apr 29, 2012 | 09:01 PM
Thanks for the replies guys. Is there anyone on the boards from around central oregon??
Old Apr 29, 2012 | 09:09 PM
Also a wet shot doesn't use the fuel injectors. A dry shot would use your fuel injectors.
Old Apr 29, 2012 | 09:34 PM
96capricemgr's Avatar
Cc503 cam
1.6 rrs
New msd opti
taylor wires
Mail order tune
I think some folks missed that.
IMO 22lbs injectors and ported heads/cam do not go together.
I would put an MSD cap and rotor on a stock opti NOT buy a complete MSD opti. Put the savings towards injectors.
Also consider your car is 20years old, it might endup needing a fuel pump to feed this. A perfect working order stock pump could likely feed it but again, your car is 20 years old so sometimes we have to change additional things..
Old Apr 29, 2012 | 09:58 PM
Yeah I missed that haha.
Old Apr 29, 2012 | 10:10 PM
96caprice.
Thank you I meant I was going with the full msd opti and does everyone reccomend a gm replacement pump? Any suggestions on injectors size brand?
Old Apr 29, 2012 | 10:12 PM
Wasnt going with full msd sorry not sure how to edit previous post
Old Apr 29, 2012 | 10:23 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Stay away from the Taylor wires. They fail quickly. Even new ones have been known to arc.
MSD wires work pretty good. Get fire boots for the plug ends.
My '94 ran best with the full MSD opti.
Old Apr 29, 2012 | 10:28 PM
Thanks paul will defaintly remember that my car has 16x miles on it is it stupid do a cam swap car seems to be well taken care of good oil pressure don't burn oil. Had the heads done bout 20k ago by prevois owner in cali what you guys think?
Old Apr 29, 2012 | 10:35 PM
16xk miles
Old Apr 29, 2012 | 10:38 PM
Paul Bell's Avatar
You wouldn't be doing a cam or head swap unless it was for a performance upgrade. There's nothing wrong with that.
Old Apr 29, 2012 | 10:40 PM
I'm just worried about bearing condition I guess if I get in there and I don't like what I see I can have the excuse to build my 383!!
Old Apr 30, 2012 | 10:23 AM
93M6Formula's Avatar
When you do the cam swap, be sure to match the cam dowel pin length of the 503 to your stock cam dowel pin length by either tapping it in with a mallet or grinding it down. It will cause major problems otherwise.
Old Apr 30, 2012 | 02:28 PM
93formula thank you, I have done a bunch of research on cam swaps an this is one thing I have made tons of notes on to not forget it, all with book marking about 8 sites with cam swap articles. I feel pretty confident. Does anyone know any good lt1 tuners here n oregon?? Idaho possibly??
Old Apr 30, 2012 | 03:29 PM
Maybe check out this Northwest U.S. section here on tech, and maybe someone near you can help you out better.
https://ls1tech.com/forums/northwest-members-66/
