No kick down and spark retard problems
I used data master and logged what was happening and saw that my tps was only showing 85% at wot so l replaced it with a new one. But it's still showing 85% at wot and it's pulling 7* timing also.
What hell could be the problem? I'm ready pull my hair out because I don't know where to start. If anyone can help or wants to look at the datamaster file please let me know!!!
Im still not understanding why its pulling timing again. After I replaced the knock sensor I data logged a few revs while sitting still and was not getting any timing pulled...then a few days later I data logged again while driving and its pulling timing again. Not sure why? or its normal while driving around under a load?
I think I have to seperate problems but any ideas would be great!
You can look at it with a DC Voltmeter as well, it should be around a half a volt closed and close to 4.5 to 5 volts all the way open., you can also slightly elongate the holes that the fasteners go through so you can adjust this.
