Opinions?? And Guess??
Here is what I have put together....
388 LTX Block
Callies billet splayed 4bolt caps
4340 Eagle 3.75 crank
6" Eagle Forged H beams
Mahle Piston
Canton 7qt pan
Custom Cam (242 246 on a 110 lsa .593 .577 lift)
CR- 11.6 / 1
AFR 210 Heads (slight port and valve job)
CSR EWP
LT4 Air gap Intake
58mm BBk Tb
MSD 6AL
Built TH350
BMR cross member
UMI Torque Arm
PHB
LCA
SFC
Engine should be in within a week or so and ready to go..
388 LTX Block
Mahle Piston
Canton 7qt pan
CR- 11.6 / 1
CSR EWP
LT4 Air gap Intake
58mm BBk Tb
MSD 6AL
Built TH350
BMR cross member
UMI Torque Arm
PHB
LCA
SFC
A lot of guys run the MSD6AL I'd prefer to have a Mallory 685. It has built in 2 step limiter and other features the MSD6AL you have to buy add ons.
Why are you running Callies Billet caps, but not their crankshaft or rods?
First, the engine is built already so it's a little late to be telling him not to waste his money on parts that are already in or on the engine.
Secondly, there's nothing "junk" about the Edelbrock LT4 intake. No, it may not be better than the factory LT4 (or even quite as good) but since they don't make those anymore they can be hard to find and/or expensive it's actually a good thing Edelbrock makes this intake.
And no, the stock intake is not a good choice for aftermarket heads with taller ports. Depending upon exact porting, the stock intake may have trouble even sealing the ports, much less the material needed to be ported to match the heads.
Welcome back, RJ. How much power it makes will be mostly dependent upon the extent to which the heads are ported. Are they the Race Ready? Or ported by somebody else? New Eliminator or older style?
You are correct about the HR cam. My plans are to break the 10.99 mark once completed. Once we hit the track and see where we are, I may end up with a SR and single plane with a LS computer swap.
I have to say around my area though I have been getting a lot of hate on my LT car. lol Everyone is saying It wont keep up with a heads and cam LS and its basically ****..lol Anyways that's the motivation to finish the project and have some fun..
