What double roller gearset for efi24x system
Old May 9, 2012 | 02:07 PM
SPOOLED UP's Avatar
Default What double roller gearset for efi24x system
is everyone using that will not push out the crank sensor alignment?
I will be using my billet cover but want to know which gearset will be perfect.
I know it needs to be near factory such as .525 thick But also still work on the ltx platform.
thanks in advance
Old May 9, 2012 | 03:31 PM
BLSolutions's Avatar
I use a cloyes 3145 with no issues.
Old May 9, 2012 | 03:40 PM
WS Sick's Avatar
What about the 1195 street roller by Cloyes?
Old May 9, 2012 | 04:03 PM
robsquikz28's Avatar
3145 works great.
Old May 9, 2012 | 07:58 PM
97Z28SS's Avatar
I have a Rollmaster double roller setup in mine with the billet TPIS timing cover and my 24x setup.
Old May 9, 2012 | 08:04 PM
Originally Posted by 97z28ss
i have a rollmaster double roller setup in mine with the billet tpis timing cover and my 24x setup.
3157?
Old May 11, 2012 | 11:15 PM
SPOOLED UP's Avatar
good to know. Are you using the billet cover?
Old May 11, 2012 | 11:16 PM
Puck's Avatar
Good to hear, I was under the impression that the 3145 wouldn't work with the 24x setup.
Old May 11, 2012 | 11:18 PM
SPOOLED UP's Avatar
I thought there was issues with all of them which is why I asked the ? about it
Old May 12, 2012 | 12:27 AM
Yes I am using the billet cover but could have clearanced my stock cover all the same. The billet cover just looks too damn good. You just need to watch and make sure the reluctor isn't pushed too far forward with a double roller setup. I'm sure other gear sets are thicker which would cause an issue.
Zero issues.
Old May 12, 2012 | 10:28 AM
SPOOLED UP's Avatar
Then I will use the 3157 and the double roller 24x reluctor and billet cover so I too can have 0 issues
