cam Ques ?????
Old May 12, 2012 | 04:59 PM
NAVY's Avatar
Question cam Ques ?????
Hi guys i want to know if this cam is good for my car ( Procharger F1R , 383 9.1cr , port lt4 heads ) .
DURATION AT .050 223/242
VALVE LIFT 530/530
LSA 114
INTAKE LOBE 108
If any one you have Advice pls
Old May 12, 2012 | 08:08 PM
bowtienut's Avatar
From the specs, it appears to be a decent blower cam.
Duration split appears a little high, but may be ok depending on how much boost you're planning to run.
Old May 12, 2012 | 08:58 PM
NAVY's Avatar
20 psi
Old May 12, 2012 | 09:17 PM
Melkor's Avatar
Question
Sounds like you've already spent a bit of coin. Why not call a cam grinder and have a custom cam ground, along with specing out the correct springs and retainers?
