Lt1 misfire (resolved)
Old May 13, 2012 | 11:52 AM
Zebisko's Avatar
Default Lt1 misfire (resolved)
Well, as many asking help and never posting the solution for the problem, I figure I should post the resolution to my problem for a change. Last year the car started misfiring after it was running for a little bit. No check engine light and no scan tool so I was on my own.
Tested some stuff, found the fuel pressure was dropping when raising the rpm, so I decided the fuel pump was bad and replaced it recently with the Racetronix unit, with no differences in running(although it starts quicker). Fuel pressure is still low, but after reading some posts, the fuel pressure seemed like it might not be my problem after all.(Those of you curious, the pressure at idle was about 41, and would drop down to about 35 when free revving to 3000 rpm approximately. BTW Is this normal operation? I'm going to add the hotwire kit for the fuel pump when I have time.)
Finally the check engine light would come on, so I finally decided to get a cable for the laptop, and checked the code, found driver's o2 sensor lean code. Looked at the measured values and found(key on engine off) that the right sensor was at about .45 volts, and that the left sensor dropped down to .004 volts. Checked it while running and it barely moved. Replaced with a denso o2 sensor, and it's running as good as it ever has.
Old May 13, 2012 | 12:33 PM
F0x Slaughter's Avatar
A word of advice, when you start any car. Get in turn the key on, put your seat belt on, check the mirrors, then start the car.
Or wait like 5 seconds for the car to prime.
Never just get in and crank a car.
Old May 14, 2012 | 04:11 PM
StraightTimeStirrups's Avatar
Make sure to put your fix in your original thread too!
