cc306 and rr
Old May 14, 2012 | 10:39 PM
1toofastlt1's Avatar
Default cc306 and rr
I'm getting ready to install a comp cam 306 I'm my buddies 96 impala and I was wondering if I should run self aligning or non self aligning roller rocker. Thanks
Old May 15, 2012 | 12:18 AM
69gto96z's Avatar
non self aligning all the way, with 7/16" studs
Old May 15, 2012 | 12:30 AM
gregrob's Avatar
If you haven't bought them yet, run 1.7s .... at least on the intake
Old May 15, 2012 | 01:04 AM
Nope I haven't bought them. So 1.7 on intake and 1.6 on exhaust? Then just guide plates right?
Old May 15, 2012 | 01:51 AM
Will there be any clearance issues with the 1.7 rr? Ptv or valve cover?
Old May 15, 2012 | 07:22 AM
96capricemgr's Avatar
What heads are on the Impala?
If untouched stock iron I believe the lift with 1.5s is enough to smash the retainer into the exhaust valve seal.
Now assuming it is iron heads since you didn't say heads and cam or tell us anything otherwise.
Also with the iron heads and pressed studs SA is your only option without removing the heads for machining.
The only case of PTV issues on a stock shortblock LT1 I ever heard of I believe to be a dishonest person who decked the block and his cam guy was a raging incompetent, for 99%+ of us PTV is a non-issue with a stock shortblock.
Valvecover clearance will depend on the rocker choosen, basically widebody or narrowbody and the clearance is not height but rather width issues with internal bracing.
