New Track Times
"wow, that will definitely be a problem.
I would have the pressure tested and make sure they have not lost lots of pressure.
As long as you can still get 145-150 lbs on the seat they will be fine. "
His exact words. I was unsure if they were actually 987's. I did not want to run springs that had been run on another engine. Who knows if the springs were actually what the PO said they were... Thats my reasoning for not using them.
*CompCams 987-16 Double Valve springs w/ dampeners:
Installed Load: 121 lbs @ 1.800"
Open Load: 343lbs @ 1.200"
Coil Bind Height: 1.150"
Spring Rate: 370 lbs/in
*CCA-4770-16 Inner spring seats
*CCA-740-16 cromemoly retainers
*CCA-613-16 10 deg Valve locks
* stock-sized Replacement valves
I just did not want to trust a spring from someone I don't know. They were probably fine but I didn't want to chance it.
Stock
My heads
Here's how it sat to be measured in the micrometer. Do I need to factor out the recess?
I got that idea from this thread...
http://www.camaroz28.com/forums/lt1-...needed-623188/
Or since you already have 1 spring off, take it to the local machine shop and have them pressure test it. For the Comp 918's you need to compress the spring .376" to match your installed height of 1.760", it should read ~140lbs at that height. And about 355 over the nose or compressed 0.954"..
