More Power
Old May 19, 2012 | 10:13 AM
Lil'Felt's Avatar
Yea I'll post some detailed pics of the motor and everything when I get home maybe you guys can steer me in the right direction
Old May 19, 2012 | 03:09 PM
F0x Slaughter's Avatar
I am assuming -31cc dished pistons, forged pistons?
Old May 19, 2012 | 05:46 PM
Lil'Felt's Avatar
Doesn't say on the spec sheet. Before I turn it loose I wanted to contact the original builder. The shops named hank and son auto out of PA?
They put it together nothing feels shitty or bad besides it needing a tube which I know is the most important part but it just says JE 8.5:1 blower pistons
Anyone ever heard of
Old May 19, 2012 | 05:53 PM
JE makes good pistons.
Your compression depends on head gasket thickness, combustion chamber size, cubic inches, and cc of the pistons.
So just because it says 8.5:1 pistons doesn't mean the engine is at 8.5:1 compression.
Old May 19, 2012 | 09:30 PM
Lil'Felt's Avatar
Yea fox you make a good point.
Old May 19, 2012 | 11:12 PM
nitrous2fast's Avatar
If you are at 8.5:1 compression.... assuming you have/add an intercooler.... you can run a LOT more than 15# of boost.
Old May 19, 2012 | 11:21 PM
Lil'Felt's Avatar
yea i really want to do an intercooler set up but it looks pretty tight down there. i will try to get some better pics then what i have in the morning.
Old May 22, 2012 | 11:17 PM
lt1slowz28's Avatar
Originally Posted by gregrob
How the hell is a wastegate (in the exhaust) going to help with pressure spikes in the intake tract...
im sorry gregrob... I may have been inebriated... edited right after you posted... I don't know why I am here tonight... must be at that point again.
