More Power
Old May 18, 2012 | 12:19 AM
Lil'Felt's Avatar
Default More Power
so i finally got my car, its a 96 ss z28 with a 355
eagle 4340 crank
lunati pro series rods
8.5:1 compression
cams are in-.503 ex-510
it also has lifters rollers and minor valve job and port work
it has 42lb injectors.
the only thing im missing is a 9in rear and axles and some wider tires.
the car makes about 490 to the rear wheels as it sits, but i was wondering what it would take to get it to 650+.
now i would like to get it tuned for this as well and i know of a place that is willing to do it but what would i need to do to get there.
i need help please!!!!
im new to camaros and again could use all the help i can get forgive me if i ask any obvious questions.
Old May 18, 2012 | 12:32 AM
93z383's Avatar
Well for the tune, where are you located? Definitely get a dyno tune with that build, a mail order tune might be OK but you'll want it spot on. How do you know how much power the car makes? I seriously doubt it's not tuned, it's necessary after a build like that.
Why do you want more power? That car is similar to my 383 build, makes around the same power and I wouldn't want any more power but that's just me.
To get to 650+ you need a power adder... that's great power for NA and about as good as it gets. Nitrous would be the cheapest/easiest, supercharger or turbo otherwise.
Old May 18, 2012 | 06:22 AM
bowtienut's Avatar
Question
This doesn't add up. Did you forget to tell us it already has a power adder?
Old May 18, 2012 | 06:43 AM
gjohnsonws6's Avatar
490 with 8.5:1 ?
Old May 18, 2012 | 06:46 AM
96capricemgr's Avatar
The compression is too low even for boost and the cam is probably just a Comp 503.
He didn't tell us anything about the heads which are a critical piece of the performance puzzle.
Old May 18, 2012 | 07:05 AM
Lil'Felt's Avatar
my bad fellas, yea it has a vortech v-2 supercharger on it. only running at 5lbs of boost.
Old May 18, 2012 | 07:49 AM
What trim? Add a meth kit, twin pumps and turn it up.
Old May 18, 2012 | 08:10 AM
93M6Formula's Avatar
With that low of compression, that thing can handle up to 15 PSI safely.(if the internals are good)
Old May 18, 2012 | 09:27 AM
Lil'Felt's Avatar
How would I go about turning it up? Different pulley? Can I get 650hp out of just turning the boost up 10lbs?
Old May 18, 2012 | 09:28 AM
Lil'Felt's Avatar
Do I need a more aggressive cam? The car is street driven as well so keep that in mind
Old May 18, 2012 | 05:26 PM
Lil'Felt's Avatar
Can someone help me with this?
Old May 18, 2012 | 09:46 PM
I don't know anything about blower sizes but a quick glance at Vortech's site says the V-2 line can make up to about 775hp. At that I would say consider a pulley change to up the boost before worrying about the cam. The cam may not be ideal but isn't that bad, and 5psi is a very small amount of boost
Old May 18, 2012 | 10:07 PM
Lil'Felt's Avatar
so to up the boost all i do is order a new pulley and belt?
and on a side note i want to get a better rear in it along with axles and good combinations you guys can think of. i want it to be able to stand the horsepower i want and more. thanks guys you been a great help.
Old May 18, 2012 | 10:23 PM
Money1's Avatar
S60 rearend
Old May 18, 2012 | 11:18 PM
Lil'Felt's Avatar
does it come with the gears and axles or are those seperate?
Old May 19, 2012 | 12:25 AM
Lil'Felt's Avatar
prolly my last question of the night. if i go above 12lbs of boost do i need a blow off valve?
Old May 19, 2012 | 12:55 AM
lt1slowz28's Avatar
you should run some sort of bypass valve.you don't want the output pressure of the supercharger to be determined solely by engine speed, it should also determined by throttle input. Usually, the bypass valve will be set so that the max available pressure for a specific RPM range is achieved at close to 100% throttle input.
is this your first F/I car?
you will need a tune (possibly other parts, fuel related items and such) with each change to boost.
What other mods does it have? (please, list everything changed from bumper to bumper.)
what is the plan with the car and is it your daily driver?
Old May 19, 2012 | 12:59 AM
gregrob's Avatar
Originally Posted by lt1slowz28
you should run some sort of wastegate on forced induction to help with possible pressure spikes. Such as, letting off at 6,000+ rpm and attempting to decelerate.
How the hell is a wastegate (in the exhaust) going to help with pressure spikes in the intake tract...
Old May 19, 2012 | 06:04 AM
Lil'Felt's Avatar
i bought the car with the supercharger and worked motor. but have the receipts n such.
i do want to get it tuned and it is street driven but i will be getting another car so that i dont put any miles on the camaro.
i can try and get in contact with the owner to see how he tuned it and what else he has into it but everything i know of is in my first couple of posts
Old May 19, 2012 | 08:50 AM
transbird95's Avatar
Don't forget to post up some pics!!!!!!!!
