Stripped Head Bolt!
Old May 19, 2012 | 10:40 PM
Zlow28's Avatar
Default Stripped Head Bolt!
As the title suggests, i have a stripped head bolt on the passengers side head. To top it off, its the very last bolt closest to the firewall. Its the actual head on the bolt, not the thread that's stripped. I tried using bolt removers but they didnt work. I cant fit a drill in there and i doubt vice grips will help much. Anyone have any ideas how i can get it out? i have very limited room.
Im thinking i should drop the engine and raise the body a little to get enough room to get a drill in there. But id like to know if there's an easier way to get that bolt out.
Thanks.
Old May 19, 2012 | 11:20 PM
rennat_2006's Avatar
Weld a nut to the head of the bolt, The bigger the nut the better and fill in the center section(where the threads are). Let it cool fully then try to remove it.
Old May 19, 2012 | 11:23 PM
THE-HOWARD's Avatar
Grab a smaller socket than what it is and hammer it over the bolt and try to break it lose
Old May 19, 2012 | 11:25 PM
Valkyn's Avatar
You could get a 90* drill and a short drill bit, might get you enough clearance to get in there.
Could also try cutting the head off another bolt and welding it onto the top of the stripped bolt, if you have enough access for that.
Edit- The welding a nut idea above is even better
Old May 19, 2012 | 11:47 PM
Zlow28's Avatar
I considered the welding idea but i dont know how to weld nor do i have the tools for that. So a friend of mine came over who has welding tools in his house, but he told me he doesnt have enough room to work in there. I dont want to get the head messed up either so that probably wont work.
I could probably try the 90* drill attachment. Ill have to check to see if they fit.
Any other ideas?
Old May 20, 2012 | 12:04 AM
You have a hell of a better chance screwing something up trying to drill it out rather than trying to weld a nut to the head of it.
Sometimes you can get lucky if it is really stripped pounding the next size down socket onto it or if that isnt close to fitting sometimes you can find a standard if the bolt is metric socket that will almost fit and can be pounded on or vice versa if it is a sae bolt using a metric socket.
Old May 20, 2012 | 12:06 AM
gregrob's Avatar
Hammer on a socket, and use the right one next time.
Old May 20, 2012 | 12:37 AM
Zlow28's Avatar
I tried using a smaller size socket, but it wouldnt lock properly. Hammering didnt help either.
Will it be too much of a PITA to remove the engine mounts, drop the engine/lift the car to give me enought room to weld another bolt head on top of the stripped one? Kinda like removing the engine, but only enough to be able to weld in there. I already have most of the wiring harness disconnected including the exhaust manifolds, but I feel like im missing something.
Old May 20, 2012 | 01:57 AM
I8ASaleen's Avatar
I haven't had a bolt yet that I couldn't pound a smaller socket onto. If you have to, strip the head a small bit more and the socket should go on. You could also try putting some dry ice on the head or a fire extinguisher to shrink it just a hair
Old May 20, 2012 | 07:04 AM
BIGCAT7274's Avatar
I take its the lower row of bolts? I would try a smaller socket first. If you weld a nut make sure your ground clamp is close to were your welding. Also disconnect your ecm.
Old May 20, 2012 | 08:02 AM
shbox's Avatar
Cut the head off the bolt with a Dremel, remove the head and the stub that is left.
Old May 20, 2012 | 08:23 AM
Speedy's Avatar
Don't flirt with disaster. Do the job properly. Take off the other head bolts, slide the head off over the broken bolt and reinstall the head with fresh bolts using thread sealer. Welding things risks damaging the head, and the last thing you want is to have that bolt snap again further down.
Old May 20, 2012 | 12:48 PM
robsquikz28's Avatar
Lol at u all. Use a turbo socket. I have used them several times even on diesal engines. They work all the time, even in the small spots.
Old May 20, 2012 | 01:14 PM
Zlow28's Avatar
This might help a bit. Its bolt #17 considering this to be the passenger's side head.
I cant fit a drill and the turbo sockets didnt work. Im gonna try to get a second opinion on the welding soon. I might just lift the engine a bit instead since im planning to switch cams soon, and that should give me enough room to work on it.
Old May 20, 2012 | 01:20 PM
whytryz28's Avatar
Well you picked the worst bolt to round thats for sure.
Old May 20, 2012 | 01:35 PM
Zlow28's Avatar
it was getting dark and the car was lifted a bit, but i just wanted to get it done. Lesson well learned.
Old May 20, 2012 | 01:50 PM
gjohnsonws6's Avatar
There is nothing wrong with welding a nut to the top of it. It not going to **** up the head. I would not try to drill it. One other option is to grind off the head of the bolt,but before doing so you better make sure the entire area is covered and that no debris can get anywhere. Same thing with welding,one bb can **** up your whole day,and if you decide to weld,damp rags will stop a bb. Also as noted put the ground clamp directly to the head casting and as close as possible to the repair area. If I was closer I would help you out.
Old May 20, 2012 | 04:51 PM
whytryz28's Avatar
Bolt #17 is recessed in the head, he wont have room to get a welder in there, no way in hell.
I had to buy a thinner socket to get to the end bolts because it was a tight fit around the bolt head.
Old May 20, 2012 | 05:15 PM
BIGCAT7274's Avatar
ouch. your going to have a hell of a time getting that one out. if you weld a nut to it. also look for a thin 1/2" nut none zinc the thinner the better. also make sure you dry up any oil laying there.
Old May 20, 2012 | 07:07 PM
Rodinator1234's Avatar
In the past I have used a extractor socket, Irwin brand from NAPA snap on sells them too. They come in a set with several different sizes. It looks like a socket with spiral threads in side instead of a 12 point or 6 point socket. http://www.irwin.com/tools/screw-bol...olt-extractors
