96 Trans Am Restoration
Old May 21, 2012 | 01:33 AM
69gto96z's Avatar
Default 96 Trans Am Restoration
I spent the weekend installing my Wolfe 6 point roll bar. I bought it from a board member a few months back for a steal of a deal. It had been sitting outside for a while, and had some rust. I sandblasted it and it was good to go.
When I pulled my interior apart, I found some rust on the floor, and some evidence of the car being hit from a previous owner, so this may turn into more of a build thread. I will update as I do things. And yes, the car will be painted back white before I am done.
Old May 21, 2012 | 02:47 AM
Brandon331's Avatar
what are these cages rated at time wise?
Old May 21, 2012 | 03:04 AM
69gto96z's Avatar
9.99 in the 1/4
Old May 21, 2012 | 05:41 AM
bufmatmuslepants's Avatar
Originally Posted by 69gto96z
9.99 in the 1/4
at 135
Old May 21, 2012 | 07:31 AM
texas94z's Avatar
Lookin' good!
Old May 21, 2012 | 09:28 AM
The Batman's Avatar
i need to find one of these, I'll probably have to buy new tho. Looks good!
Old May 21, 2012 | 09:38 AM
lethal bird's Avatar
I plan on just buying the bolt in set up some time in the future.
Old May 21, 2012 | 03:06 PM
69gto96z's Avatar
I don't blame you on the bolt in. If I hadnt gotten the deal I did on this one. I would have gone with a bolt in.
Old May 21, 2012 | 03:37 PM
AChotrod's Avatar
I got the bolt in so it could easily be taken out and sold when I upgrade.
Old May 21, 2012 | 10:11 PM
69gto96z's Avatar
Did some more work today. I yanked the dash, removed the HVAC stuff. A few months back I pulled the AC, cut the box out of the engine bay, and kept heat. Now it is all coming out, but I am going to mount a heater in the car, with vents, but will not be using the factory stuff. I also began grinding out more rust, and removed a good amount of seam sealer because I found rust behind some of it when I was putting the roll bar in.
Old May 25, 2012 | 05:34 PM
tektrans's Avatar
Pretty sure that has to be tig welded to pass NHRA tech.
Old May 25, 2012 | 10:00 PM
trans_am7935's Avatar
i was looking at this same roll bar, but i have seen it in bolt on (or at least one that looked like it) are these not legal for the drag strip?
why are removable crossbars not NHRA legal?
Old May 26, 2012 | 10:41 AM
gjohnsonws6's Avatar
10 point to 8.50 can be mild steel or moly,mild steel can be mig or tig, all welds complete and no grinding. Moly must be tig welded.
Old May 26, 2012 | 11:55 AM
69gto96z's Avatar
I am not sure why they aren't legal, but I welded mine up just to be safe.
The roll bar is mild steel so Mig is just fine
Old May 26, 2012 | 12:09 PM
69gto96z's Avatar
Did some more work this week. Ground all of the rust out of the backside of the floor with a various combination of wire wheels, welded in patch panels where the floor had rusted through, and where I had my nitrous mount years ago on the rear hump. Then the back half of the floor got the first coat of primer yesterday. I also found a crack in the floor behind the pedals that goes right into the engine bay behind the drivers side header. All of the welds in the patch panels are very ugly haha, my dad let me borrow his crappy flux core for welding them in. It sure doesn't weld pretty, but it gets the job done. The roll bar was NOT welded in with flux core however.
Cut rear interior panels to fit the roll bar
The crack in the floor
Old May 26, 2012 | 07:21 PM
69gto96z's Avatar
Applied new seam sealer and gave it a second coat of primer. First coat of white will go on tomorrow.
Old May 27, 2012 | 05:26 PM
69gto96z's Avatar
Got the first coat of white on today. If anybody is wondering why I am only painting half of the floor, it was already stripped to bare metal in a few places, and it is supposed to rain next week. I didn't want to take te chance of the humidity causing surface rust, and having to grind it again. The front side of the floor will be done once I finish painting the rear section.
Old May 28, 2012 | 04:10 AM
v7guy's Avatar
What kind of paint did you brush on?
Old May 28, 2012 | 05:53 AM
transbird95's Avatar
Looks good, I'll be doing this soon as well.
Old May 28, 2012 | 07:27 AM
whytryz28's Avatar
Looking good with the install.
