LT1 383 valvetrain problems FIXXED THANKS EVERYONE THAT HELPED
I hear ya, one time I had a coil wire that was so bad it was making a snap noise on its misfire (firing to the side of the waterpump), I had the stethescope out running all over the engine. I checked my tranny fluid one night and it had such a pretty orange light up front snapping away...lol
that is an odd sound for an exhaust leak though I would say. When my SLP headers leaked it sounded more like a tap sound vs this one which does have alittle bit a metal on metal sound to it.
Village Troll
Easiest way to tell whether or not a "tick" is an exhaust leak is to put the car in a high gear when rolling and accelerate. If the "tick" gets louder then it's more than likely an exhaust leak.
That video... that is the funniest leak I've ever heard. Sounded exactly like something was squeaking.
#33
LOL that's exactly what baffled me before a couple of years ago! I wish I'dve seen this post before now. I had a thread about it also. I wound up going thru the entire valve train checking everything and even went so far as new push rods, guide plates, new lifters from Howards Cams, and had the Comp hi tech stainless rockers rebuilt, and a new hardened oil pump drive shaft. All of which were probably needed anyway as maintenance for an, at the time 15 year old motor, but it turned out to be the crappy Kooks header gaskets! The noise was rpm specific too it was prevalent from 1500-2500ish rpm.
We discovered it when an LS Trans am came into the shop with a crazy squeak too. I grabbed some welding gloves and grabbed the #2 cylinder header primary at the head and the squeak went away. I started laughing because I knew I had just solved my own problem. Put my car on the lift and both #7 and #8 had a lil soot around the gaskets. Replaced them with Fel-Pro 1406s and for $20 all was well....oh and the other $500 of trouble shooting! I would have bet anything that it was a mechanical noise. Glad you found it and hopefully others will keep these threads in mind when they have similar issues.
--Alan
--Alan
