oil coolers
Old 06-01-2012, 10:08 PM
tricked94camaro's Avatar
i sucked it up and ordered a Melling (MFA350) i supposed the whole $22 is worth it haha
Old 06-04-2012, 12:55 PM
Does it matter which way I bolt it in? Which side does the spring go on? And which bolts do I use? I picked up some one inch allen head bolts but they protrude the surface that meets the filter gasket and I knew that wasnt good. Do I just get regular 6 point bolts?
Posted from LS1Tech.com App for Android
Old 06-05-2012, 06:25 PM
does it matter which side the spring is on? its currently positioned on the inside....
Old 06-05-2012, 06:26 PM
also, which fram filter to use???
Old 06-05-2012, 08:30 PM
96capricemgr's Avatar
Not a fram basically anything but fram.
When I ran that adapter I just looked up say an 80s big block truck figuring that was likely to give me a long filter.
Old 06-05-2012, 10:39 PM
that doesnt really help
Old 06-05-2012, 11:45 PM
That's MISTER MODERATOR
Paul Bell's Avatar
LS1Tech 10 Year
Did somebody say Fram??
Mobil One Extended, Wix, Car Quest, K&N, Cummins are all good.
Stay away from Fram, STP, Penzoil, store brands and Fram.
Old 06-05-2012, 11:51 PM
Paul Bell's Avatar
LS1Tech 10 Year
The more expensive Bosch filters are OK too.
Bosch makes pro sound gear, oil filters, dish washers, electric tools, tire mounting & balancing machines, telecommunications, fuel injectors............
Old 06-05-2012, 11:55 PM
ts wrong with fram? ive been using them since forever and never had a problem. anyways, got a part number for the filters you listed that will fit my motor???
Old 06-06-2012, 06:52 AM
Paul Bell's Avatar
LS1Tech 10 Year
What number filter are you currently using?
Old 06-06-2012, 07:31 AM
i havent gotten one yet. i havent completed the swap
Quick Reply: oil coolers
