Vac ports/ plugs and pcv plugs
I got my intake back from A.I. they provided the core. Its dont have any of the vac ports in it. I only need a few because i have alot of things deleted (a/c, pcv, ect..) Who sells the port and plugs? I call summit and they said i needed the size and tread. I need a plug for the large and small pcv holes aswell. Im running the moroso vent system someone posted in ACHOTRODS thread.
PCV is deleted and is just looped right now and id rater just block it off to make it look cleaner. Im using the kit to vent the crank case pressure to the exhaust so no oil goes into the intake or all over via a breather. The car is going to be mostly a track car and prob via a trailer with my th400 going in with the new motor.
