obdII to obdI conversion issues
i have checked all grounds from the pcm and all are good and have a good connection, but there might be something else i need to do. do i need to get a different aldl port?
thanks for the help guys
2) As for the no crank but no start. Confirm the usual suspects... fuel pressure to rule out fuel delivery. Then check ignition. I suspect there may be an issue there causing the coil not to fire or ICM not to do its job.
I know it isn't much but this is where I would start. Good luck!
but why is the key not priming the pump? never had that issue before. the only thing i dont have hooked up right now is the alternator, but that cant be the issue, i have a bettery charger on it at all times, im waiting for my madman low mount kit to get here. everything else is hooked up.
From what I gather, you are using an OBDII style connector, but with an OBDI pcm. I did some research, If you are using an OBDII code reader it will not work. You need an OBDI reader with the appropriate OBDII style connector. Don't forget also you need the 12v adapter for OBDI readers.
The appropriate cable is sold at http://www.tunercat.com/, you will need USB/ALDL-2.
It has fired a couple times but when it would'nt anymore I swapped the computer into my 95 Z28 and found out it's dead there, won't fire the 95.
So now in the 97 no fuel pump prime with turning the key "on",...but fuel pump primes with a jumper wire to the prime connector underhood.??!?!?!?
If you get on Shbox's site you can see the different pin outs on the connector faces of the harness(not the PCM, the harness),...here's the link to what I'm talking about.
http://shbox.com/1/harness_connector_faces.htm
(note: the links to the different connector faces are available on a menu near the bottom of this link)
They are different year to year.
THIS is where our problems are, in the harness connections.
I thought I changed mine correctly and like I said, at one time the set up allowed me to fire up my car and run it a couple times,...then it ran like **** a couple times and then last night I find the PCM is non working,...I know because I swapped it into my good running 95 Z28 and it would'nt fire that car at all.
I'm wondering if I did something that is frying the PCM?
I've got another OBDI computer and I'll try that one,...pretty sure we need to figure out the fuel relay wiring, at least.
Those weird noises you sometimes hear, that's me pulling out my hair,...f**k the receding hairline,...I'm pulling it out?!.
