padding to wedge between y pipe and frame
Old Jun 11, 2012 | 08:53 AM
bufmatmuslepants's Avatar
More than likely saggy motor mounts has something to do with this, I would replace them with eurathane ones, should lift your motor up at least a half inch.
Old Jun 11, 2012 | 09:07 AM
FAD2BLK93's Avatar
Wouldn't lifting the motor make this problem worse?
Old Jun 11, 2012 | 09:10 AM
Is it rubbing on the body or the K member? Its common for them to rub on the K member.
Old Jun 11, 2012 | 02:31 PM
9D4Z28's Avatar
yeah its to tight to the car. it needs to drop. not the k member, where the indent on the driver side of the y pipe is. it's so close that it's vibrating on the body the car when the engine is running
Posted from LS1Tech.com App for Android
9D4Z28's Avatar
it's not touching but way too close to where it makes noise and it rubs
Old Jun 12, 2012 | 08:53 AM
Wayfastwhitie6's Avatar
Disconnect your y-pipe from the rest of your exhaust and use it as an "extension" to pry the header down. I also had a buddy use a long prybar on the header to help tweek it. Thats what i did and it worked like a charm :-)
Old Jun 12, 2012 | 12:49 PM
Gojira94's Avatar
Exhaust adjustment as described above... and there is a product called 'inswool' ceramic fiber blanketing you can use to insulate things you want to keep cool from radiant heat, like your brake lines and fuel lines on the driver's side. 2400* on one side and near-ambient on the other, 1" away. Commonly used to line forges.
Old Jun 12, 2012 | 01:02 PM
Jersey Mike's Avatar
I remember people here shoving steel wool between their Y-Pipes and floorboards.
Old Jun 12, 2012 | 07:09 PM
9D4Z28's Avatar
really appreciate it guys. ill try prying first and I'll look into the inswool thanks for the help very helpful.
