Procharger question
Old Jun 8, 2012 | 03:46 PM
shaq_2500's Avatar
Default Procharger question
My compression is 11:5 ratio can I procharge my motor and use methol on my forged bottom end setup and be safe
Old Jun 8, 2012 | 07:41 PM
Bigtoyz's Avatar
Probably about 4-7 psi. When I had factory compression I was run 9-10 psi on 92 pump gas. I put in a boost retard so I could dial it back if I ran into bad tank of fuel. The meth should really help also.
Old Jun 8, 2012 | 09:20 PM
Blackbirdws6's Avatar
I wouldn't unless you don't plan on running much boost.
