Floor soaked.
Old Jun 10, 2012 | 02:13 AM
Blind898's Avatar
Default Floor soaked.
So iv noticed a smell in the car for about a week now and tonight i was messing with stuff in my glove box when something told me to look under the passenger floor mat, so i did and bam. Floor soaked to the bone. So bad you could see standing water almost. Im rage pissed cuz last month i detailed the inside of the car spotless. Iv had the car for over a year now with no issues with rain or leaks. We did have alot of rain last month or so but like i said i detailed the inside and it wasn't there. The liquid didnt have a smell but you could smell a sorta mildew smell. Without fully ruling out some jackass friend spilled something and didnt tell me, what would be the best way to test for a leak and would there be any other cause for water to collect on the passenger side floor? Also whats my best way to clean this without fully taking out the carpet? Atm i took some rags to soak it mostly up and scrubbed it with carpet cleaner i had around the house.
Old Jun 10, 2012 | 02:27 AM
stevo9389's Avatar
might wanna check your coolant level as you could have a leaking heater core.
Old Jun 10, 2012 | 09:48 AM
SS RRR's Avatar
Village Troll
Leaking heater core or clogged A/C condensation vent are my guesses...
Old Jun 10, 2012 | 09:53 AM
shbox's Avatar
Indeed or that Big Gulp got away...
Old Jun 10, 2012 | 10:26 AM
Dave357LT1's Avatar
Its polar pop now lol
Old Jun 10, 2012 | 01:18 PM
Blind898's Avatar
Coolant lvs are fine atm but I'm still gana check it when I get home. I'm getting air in my coolant system and this might be why.
Old Jun 10, 2012 | 08:18 PM
Blind898's Avatar
Not the heater core. Took the glove box off and the cover. Ran the car for a good while with the heat on then let it cool. Checked everything no coolant smell or any signs of it leaking. Gana check maybe i got a leaking window now :/
Old Jun 10, 2012 | 10:04 PM
SilverSS07's Avatar
Check grommets in the firewall and the seal around the windshield also.
Old Jun 11, 2012 | 06:46 AM
SS RRR's Avatar
Village Troll
No A/C?
Old Jun 11, 2012 | 10:17 AM
sweetbmxrider's Avatar
Yeah if you have a/c, the drain may be clogged. Otherwise, look at the window seals and how tightly the window seats against them. Is it a ttop car?
Old Jun 11, 2012 | 04:38 PM
Blind898's Avatar
Ok found out. If the passenger side window rolls up with the door shut its not sealing all the way. open the door roll the window up then shut the door there's no leaks.
