Gm 847???
No power down low and (stock casting) head limited power up high. This will result in a narrow torque curve that would mimic a four banger to some degree. You might also find yourself getting beat on the street or strip by less capable cars. Lack of power down low will also make it difficult to drive just normally on the street too especially with a stick IE: cam surge, bucking etc.
You should consider a smaller cam 22x/23x at the most with a tight 107LSA and you will have a much better performing cam and the sound you want. Tight LSAa and overlap make the lumpy idle sound. 847 and stock castings is just overall not smart.
