jet performance chip?
Old Jun 12, 2012 | 02:35 PM
1quickz's Avatar
Default jet performance chip?
i cant get it to work i plug it in and the service engine light comes on? ive messed with seems to not fit very well. any ideas on what to do ?
Old Jun 12, 2012 | 02:45 PM
ahritchie's Avatar
I had one of these long ago...back in the 90's when there were virtually no tuners for LT1s. Not really worth any HP gains IMO....there was a wire coming from the JET module that has to be spliced with a certain pink PCM wire I seem to recall....but you need the directions to find out which specific wire to splice. I don't remember as it was forever ago. Once installed mine never gave any check engine lights. You would be much better off to just get a mail order tune.
Old Jun 12, 2012 | 02:57 PM
LT1FirebirdSLP's Avatar
+1 on the mail order tune.
Remove PCM from under cowl (2-10 mm bolts)
Unhook the red blue white and gray pigtails
Remove the two 1/4" bolts holding the plastic cover to the PCM
Pack and ship to your tuner of choice
Takes 10 minutes. Much easier.
Tuners include madz28, pcmforless, Lt1pcmtuning.com aka Solomon. The choice is yours here. I can't speak for any of those vendors except madZ28, his turnaround was super quick and everything you can think of is essentially tunable, although I haven't run his tune yet in my car. Just search and find one you are comfortable with. Good luck.
Old Jun 12, 2012 | 03:06 PM
lt1-xjs's Avatar
Why the Jet module ? Your car would have to already have a custom tune to run.
Old Jun 12, 2012 | 03:37 PM
bufmatmuslepants's Avatar
Are you trying to use this on the car in your sig? If so I need to find a good picture of a facepalm.
