HVAC box delete ?'s
I'm removing the heater box and just as much extra junk as possible. Going to go thru the wiring harness and delete the mass amount of wiring not used. What are these two boxes? The black one is located at the passengerside kick panel. The silver one was behind the glovebox attached to the vent tubes plastic.
And what is this box behind my shifter under the console. I'd like to move it and delete the console if I can.
Also, I have manual doors to install. I am not seeing an easy spot to disconnect the wiring so the doors can take the wiring with correct connections. Do I just cut the things between the door and body?
You might have to unPlug the door harness from there connectors inside the doors, then Slide it out from the side . I have yet to actually way my manual doors and truly see if it's lighter then a electric power door ... You sure have alot less wires with a manual . You removing the door bars to ?
