Trans leak e
Old Jun 22, 2012 | 10:43 PM
bBody22's Avatar
Default Trans leak e
i have a 4l60E and i change my trans filter and pan gasket and now i have i bad leak i put grease around the pan per instrustions or should i have not done that. what should i have use if anything
Thanks for the help
Old Jun 23, 2012 | 12:39 AM
nomoneyz's Avatar
Never heard of putting grease on the pan. Was it a rubber gasket or a paper one? Did you over tighten the bolts?
Old Jun 23, 2012 | 07:40 AM
Paul Bell's Avatar
That's MISTER MODERATOR
Get the Victor Reinz Tuff-Cork gasket, W39365TC for the 4L60E. It has a steel core.
http://www.rockauto.com/catalog/moreinfo.php?pk=3654483
Make sure the top gear solenoid purge port located in the pan rail isn't covered by the gasket. Some aftermarket aluminum pans will also cover this port and need to be ground.
Old Jun 29, 2012 | 06:20 PM
bBody22's Avatar
yes rubber gasket
Old Jun 29, 2012 | 08:25 PM
Paul Bell's Avatar
Yeah, grease is an old trick to get it to stay put during installation-and make it easier to remove the next time.
It doesn't work so well on these transmissions as the OP has found out.
I knew a "mechanic" who used floor tile adhesive on transmission pan and differential cover gaskets. They never leaked but you'd need a freekin jackhammer to get them off.
Go with the Tuff-Cork stuff guys.
Old Jun 29, 2012 | 10:37 PM
defaultexistence's Avatar
Troll.
Old Jun 29, 2012 | 11:17 PM
bBody22's Avatar
i couldnt find that gasket on there website
Old Jun 29, 2012 | 11:58 PM
Paul Bell's Avatar
*SIGH*
-Go to the Rockauto website.
-Enter the website at the red dot start button.
-Choose your make.
-Choose your year.
-Choose your vehicle.
-Choose your engine.
-Choose transmission-automatic.
-Choose oil pan gasket.
-Find Victor Rienz "Tuff-Cork" in the list.
-Purchase said gasket.
