newby need help w lt1 build
Old Jun 23, 2012 | 02:06 AM
z28master's Avatar
Default newby need help w lt1 build
ok so i was reading up on here about what to do to my 94 z28 and from the posts ive read and videos i ve seen i had determined to just put a 5.3 in it and hook turbo up, but i asked my cousin about it and he said would be big trouble getting it to run with pcm etc. he said to keep my lt1 build it and hook my turbo up, he also says that performance parts would not really be needed just to build the motor with durability parts so it would hold up that my turbo would be the performance parts, so my question is... what exactly do i need to put in it with being on a budget? i ve got a t3/t4 kit had nitrous kit but now im trying to get rid of it. also anyone that has parts i need or could use let me know i would like to buy my stuff from here instead of jegs or somewhere alot more expensive. thanks a bunch to the guys that reply. ive read alot alot of stuff on here and sounds like most is very knowledgeable. ps. my cousin is pretty high up in advanced auto stores and has 800+cobra in case someone is like wtf or something from how the top of post looks but he is like beating info out of so.......well, im here. THANKS.
Old Jun 23, 2012 | 02:12 AM
tt383lt1's Avatar
i would ditch the lt1 and go 5.3 with a stand alone harness. simple and way more better than the lt1. it has coil on plug, obd2, easier tuning, diagnostics, handle more hp then the lt1 ( stock to stock). hands down way better and the resell will be better too.
Old Jun 23, 2012 | 03:02 AM
z28master's Avatar
What was my cousin tlkn bout not gettin it to run w the ls cam an intake, about the computer. Im new to it all. Thanks for reply so quick.
Old Jun 23, 2012 | 04:10 AM
Bigtoyz's Avatar
If I had to do it all over again I would do 5.3 or 6.0. The 5.3 was tested to handle 1200-1300hp turbo'd stock with nothing done to it. 6.0 is good for 600hp but have to change out the stock pistons are the weak link is what I have read.
Like said above get stand alone ecm........and boost the bitch.....
For the same amount of money to build a LT1 you can do a 6.0 to the hilt. And take a junk yard 5.3 and have more fun and not worry about it when it blows.....take it out another 500 bucks and do it all over again
P.S. Your cousin better stay in the car audio world.... j/k
Old Jun 23, 2012 | 04:39 AM
tt383lt1's Avatar
i think they regaped the rings and put a new intake on the 5.3 to handle the hp. but still. and if you do decide to go any ls engine. there is unlimited parts on here for alot cheaper than any where else. like intakes, hot pipes. ect
Old Jun 23, 2012 | 07:19 AM
96capricemgr's Avatar
What are your goals for the car?
The LT1 is capable of more than most people want to believe and an LS swap will nickle and dime you FAR more than most people want to admit.
Old Jun 23, 2012 | 09:35 AM
bahamianprince7's Avatar
Lt1 block for sale.. No accessories.. $100 386 338 7780 Florida
Old Jun 23, 2012 | 08:55 PM
z28master's Avatar
Im just wanting the cheapest route i can go obviously. I don't expect to have the fastest car by no means just around 600 hp ish. I think im gonna keep my lt1 since i already have one instead of buying somethin else. I already have a turbo kit also. MY NEW QUESTION WOULD BE WHAT DO I need TO PUT IN THE LT1 TO HANDLE 600 ISH HP? WITH MY TURBO
Old Jun 23, 2012 | 08:58 PM
z28master's Avatar
Also to MAKE 600 hp not just handle it. I look for my turbo to put me only around the 500LT1 ish range.
Old Jun 23, 2012 | 08:59 PM
z28master's Avatar
500 hp range. Sorry.
Old Jun 23, 2012 | 09:29 PM
warriorcustoms's Avatar
Theres guys makin 1000hp with LT1 motors & Turbos google it theyll pop up lol How fast you wanna go = How much you wanna Spend Youve already got the LT1 500 or 600 boosted Aint hard I will be at 600hp on the motor with my 396 LTx
Old Jun 24, 2012 | 01:44 AM
z28master's Avatar
Thanks what you got in it?
Old Jul 2, 2012 | 01:29 AM
z28master's Avatar
Thanks to everyone that left replies with info i have now changed my mind to just sell everything i have and buy my grandpas ws6 it is cheaper than wat ill have in mine to get where i want it. So i have 94z28 w/350 turbo nitrous kit and turbo kit 36lbthat inj. A bunch of stuff hell of a deal ALL for 2000.00
Old Jul 2, 2012 | 01:30 AM
z28master's Avatar
Also borla and flowmaster exhaust
