Replacement Power Steering Pump
Old Jun 23, 2012 | 04:54 PM
n2oblkz's Avatar
Default Replacement Power Steering Pump
I have a 1996 Z28 and the power steering pump is leaking, not a lot, but enough that it really bothers me. Anyway, any suggestions on the brand of replacement pump (I was looking at the Cardone's through Rock Auto)? Also, do you think that it would be wise to go ahead and replace all of the P/S fluid lines when I do this? The car only has 33K miles on it.
Thanks!
Old Jun 23, 2012 | 06:52 PM
Rob94hawk's Avatar
Thanks!
Unless the lines are starting to crack keep them. It might be a bit overkill (in your case it might not be since from your sig you have all bolt-ons) but if you have the coin I recommend a Turn One pump which requires your core:
http://www.turnone-steering.com/gm-f-body-lt1-pump/
Don't know if they still make the aluminum pulley though and Speed Inc. seems to be out of stock on them. Mine looks like this:
Old Jun 23, 2012 | 06:59 PM
Boosted Firehawk's Avatar
I have a stock pump with pulley 50 shipped
n2oblkz's Avatar
OK, thanks. I wasn't clear on the Turn One pump, I may just wait a while and go with one of those.
Old Jun 23, 2012 | 07:04 PM
n2oblkz's Avatar
New or used?
Old Jun 23, 2012 | 08:56 PM
Valkyn's Avatar
I recently got a turnone pump from rock auto and it looks good. I also replaced all the lines while I was in there.
I had to make a tool to remove the pulley but it wasnt too bad. I thought about getting an aftermarket pulley like Rob94hawk has but really you cant see the pulley whatsoever when everything is installed, so I just ended up painting my original one and calling it good.
NM I got the Atsco pump from rockauto
Old Jun 23, 2012 | 09:51 PM
mezzyshreder's Avatar
I always replace with original oem whenever possibl0e. Who is turnone?
Old Jun 23, 2012 | 11:20 PM
Mine is used
Old Jun 23, 2012 | 11:33 PM
Rob94hawk's Avatar
http://www.gmhightechperformance.com...l/viewall.html
