need to do headgaskets what company?
Old Jun 28, 2012 | 04:16 PM
daddyoisback's Avatar
Default need to do headgaskets what company?
have to do the HG on my swap had water coming out the sparkplug hole when i was bolting up my converter... did a search for best HG but didn't come up with much (alot of post with keyword head gasket lol) basicly heads n cam motor still a 350 going to be street driven more then track keeping it NA so what would be my best bet?
Old Jun 28, 2012 | 04:22 PM
katz_2003's Avatar
I used reccomend using a .026 gasket like mr. gasket part number 5716G or Victor Reinz (dont know part #) they are pretty cheap and work well and will also bump up your compression a little. I have had good experience with them, for awhile I heard they were having problems with coating sticking to the wrap but I never had this happen to me and i've used a couple sets of them on cars with no issues.
Old Jun 28, 2012 | 05:08 PM
RamAir95TA's Avatar
Mr. Gasket 5716s would work well (check for de-lamination prior to intalling though). That or OEM Impala gaskets.
Old Jun 28, 2012 | 06:28 PM
purpleflamzz's Avatar
I would suggest cometics mls that way you can reuse if needed and there all steel.
Old Jun 28, 2012 | 06:33 PM
FAD2BLK93's Avatar
I used Mr Gasket .026 gaskets. Go slow when u pull them out of the packaging.
Old Jun 28, 2012 | 06:34 PM
thanks for the quick replys and part#'s what is different about the impala gasket? was going to buy a felpro kit heads intake water etc. but thought i'd c what was more the norm for LT1's since i already have to get special part #'s for the intake and headers anyone have the cometics #?
Old Jun 28, 2012 | 07:57 PM
defaultexistence's Avatar
the impala head gasket is a thinner stock gasket then an f-body gasket if i remember correctly its in the .030+ range ..its a popular choice to bump up compression and unleash a few more ponies.. just like the others listed above will do... don't use cometic gaskets unless the block and head surfaces are dead nutz perfect. i recommend a fel pro Performance gasket i'm using a felpro 1074 its .039
Old Jun 28, 2012 | 08:10 PM
looked into the cometic they look nice but what sucks is i dont want to let the car sit without the heads on it whiile i wait for headgaskets to be delievered (pulling everything off checking for flatness) want to have evrything ready n do it all in one day..unless there is something i could put on the block pistons etc. when it sits for a cpl days thanks again
Old Jun 28, 2012 | 08:17 PM
ANY auto parts house can get any of the listed gaskets overnight in most cases ...and u pay no shipping
Old Jun 28, 2012 | 08:23 PM
speed_demon24's Avatar
I went with the impala gaskets. I don't trust a company that can't seem to package a gasket so it won't be ruined by opening the packaging.
Old Jun 28, 2012 | 08:29 PM
96lt1m6's Avatar
I prefer the Felpro blue stripes(permatorque) series been using them for 25 years with NO failures!
If you use the felpros I do suggest having your heads milled 15-20 thousandths to bump the compression up a bit
Old Jun 29, 2012 | 05:07 PM
thanks for the help guys...going to do a little more 'search' and google'n before i buy most likely going with the felpro
Old Jun 29, 2012 | 08:34 PM
Speedy's Avatar
I went with the Felpro too. It's a good, reliable gasket. I would rather mill .02 than risk disaster with a thinner gasket.
Old Jun 30, 2012 | 01:11 PM
ordered my gaskets today
