Stock DD 2 get cam help
Old Jun 30, 2012 | 01:27 AM
bizerk1's Avatar
Default Stock DD 2 get cam help
Hey, so I have been looking at cams, I am trying to budget this through ones in the marketplace here, I have been thinking about hotcam, but I want a bit more i think, but not quite cc503, this is DD spring an summer with permitting weather. I know I need 1.6rr, pushrod,guideplates, springs.
So my question what cam do you guys recommend and what size stall, if I were to go with hotcam do you need to change the tq converter?
Mods listed in sig.
trying to do the homework before final decisions
Old Jun 30, 2012 | 01:34 AM
Adam1203's Avatar
I have the cc502 which is very similar to the hotcam but has just a little more mid range to it i believe. You will need gaskets, springs, rockers, possibly push rods, as well as timing chain set I am probably missing something.
I went with a stock converter for a while after the cam and at lights it was hard to hold the car back it just wanted to break through the brakes. I have a 3600 vig that i bought because i got a good deal. I feel that a 3200 would probably have been perfect for this cam though.
Old Jun 30, 2012 | 01:53 AM
bizerk1's Avatar
you have any vids of idle and drive bys or in car pulls? I only see 503 on youtube.
Old Jun 30, 2012 | 02:52 AM
96lt1m6's Avatar
Any aftermarket cam you could buy will benefit from a stall hell even the stock cam needs one! If you are wanting a cam that pulls hard and is barely detected. It has a very slight chop at idle, you need an LPE 211/219 this cam is highly underestimated by many........
If that is not enough next up would be the 503 this cam is super universal pulls hard, has a great sound and won't kill fuel mileage.......
Old Jun 30, 2012 | 09:39 AM
Adam1203's Avatar
I do not and I dont have the capability of it either. the cam has a very mild sound to it so it is noticeable at idle but not obnoxiously. I get a lot of compliments on how the car sounds with this cam and the magnaflow. I calculate every tank of gas in the car to and I average 14 mpg in the city and on a road trip i just took i did 23mpg on the high way with my set up. Again my car is a A4 with cc502, 3600 vig, 3.42 gears.
Old Jun 30, 2012 | 10:34 AM
guppymech's Avatar
I have a hotcam and really like it. I picked up 6.5 mph with just the cam change, using lt4 valve springs with stock 1.5 stamped rockers. Here's a link to a discussion of 503 vs hotcam:
http://www.ls1lt1.com/forum/lt1-|-lt...am-budget.html
I'm local to you, you could come by if you want.
Old Jun 30, 2012 | 10:44 AM
defaultexistence's Avatar
For the same price as off the shelf get a custom grind from Lloyd Elliott or Advanced Induction..
Old Jun 30, 2012 | 10:55 AM
SPOOLED UP's Avatar
I have a xfi280 cam if your interested
Old Jun 30, 2012 | 01:37 PM
94LTZ's Avatar
I've had many cams that i DD with over the years, CC305, CC306 this thing was a beast with my set up, LT4 hot cam kit, L.E. custom grind big bitch lol.
I know alot of guys hate on the CC306 but with the set up i had she ran strong as hell, even gregrob gave it props in my car and he hates that cam with a passion, But if i had to to do it all over again i would have done a custom grind first. I've personally seen gregrobs car with his old cam that he speced along with another one he did and they were suttle cams that ran hard *** hell.
I would send him a PM and see if he would be willing to help you man, you wont regret it one bit.
Just my .02
Old Jun 30, 2012 | 05:21 PM
bizerk1's Avatar
I was interested in hotcam b.c I know there are a few on the market and could be picked up cheap. I dont know the route I am going to go with yet engine wise heads/cam or ls route one day, but until then would like to get more power. Custom grinds are usually specific to the setup and I feel finding a used off shelf cam or hot cam would be easier to find. Like I said it sounds like every1 always wants to upgrade after hotcam so, I would like a bit more. I will look into ones suggest, do I need to up the injectors?
Old Jul 1, 2012 | 08:09 PM
bizerk1's Avatar
what gains could be expected from the lpe is it between hotcam and 503? who has these?
Posted from LS1Tech.com App for Android
Old Jul 1, 2012 | 08:18 PM
Blk98Vert's Avatar
I had a 228/236 from LE, I think many will agree that that and the 226/234 from AI are gaining popularity
