any th400 users with stock 10 bolt?
Im still on a 10 bolt with my car. Had a local shop build a driveshaft for it. 47 1/2" is what the final length ended up being and I used a UMI crossmember with a poly mount.
I just recently installed a th350 short tail trans with a bmr cross member made for the 350. As for the drive shaft I ordered one from spohn that was already the correct length for the short tail with the 1350 u-joint. However after a few things came up, I have had to push my 12 bolt rear end off for about a month and now picked up a Napa joint to use with my stock rear end to get the car rolling for the initial tuning process.
http://www.spohn.net/shop/1982-1992-...hort-Tail.html
