coolant sensor light on
Old Jul 3, 2012 | 07:28 AM
9D4Z28's Avatar
Default coolant sensor light on
the shop told me I had a bad coolant sensor in that's why my light was on in my dash. are you place a sensor filled the coolant and the light is still on? any ideas ? maybe the harness is bad?
Posted from LS1Tech.com App for Android
Old Jul 3, 2012 | 07:29 AM
9D4Z28's Avatar
sorry speak text. I replaced the sensor and filled the coolant up. the light is still on
Old Jul 3, 2012 | 07:38 AM
shbox's Avatar
Check the coolant level when cold to be sure it is full (hopefully, you bled the system properly). You can also unplug the harness to see if the lamp goes out.
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
Old Jul 3, 2012 | 10:36 AM
SS RRR's Avatar
Village Troll
Those sensors are infamous for getting gunk in them and not reading correctly. If what shoebox recommends doesn't work, take it out and see if it needs cleaning. If not, replace it.
Old Jul 3, 2012 | 12:01 PM
DisasterFormula's Avatar
Honestly, there isn't much you can do. Mine came on nice and bright. Filled up the coolant since it was a little low with a 50/50 mix and it would be dim when I fired it up, then turn on bright. Replaced the sensor and it still came on. Unplugged it and the light went out. About all you can do, sometimes.
Old Jul 7, 2012 | 02:45 PM
Vejita88's Avatar
Thanks guys for the info. It answered many questions I had.
Old Jul 8, 2012 | 12:00 AM
fex77k's Avatar
My stock one lit up after 100k miles, the part store brand didnt work either. i found a cheap oem that worked.
Old Jul 8, 2012 | 10:45 AM
93lt-T/A's Avatar
Go to the junk yard an get one. Mine comes on when I start the car then turns off after about 2 minutes.
