Gen 1 swap question
Old Jul 7, 2012 | 10:07 PM
1C3 MAN's Avatar
Default Gen 1 swap question
Hey guys i need to know from the guys who have done this swap or know alot about this swap.
I have the chance to pick up a UMI K-member for an LT1 for really cheap. And im about to swap in a 400 sbc and need to know if i can make it work?
I know they make a sbc/BBC conversion K-member for our cars but can i make the regular one work without a ton of mods?
Old Jul 7, 2012 | 10:10 PM
xtreme2001's Avatar
yes you can make it work.i had a 94 z28 and used the lt1 kmember and stock lt1 mounts..so no reason why you couldnt use teh umi kmember
Old Jul 7, 2012 | 10:20 PM
1C3 MAN's Avatar
did all the holes line up?
what did you have to do to make it work?
everywhere i read it says one side will fit fine and the other side one 2 out of the 3 holes will line up.
Old Jul 7, 2012 | 10:45 PM
duh's Avatar
duh
They should line up fine. From every LTx block I've seen they all have the traditional sbc mounting pad.
Old Jul 7, 2012 | 11:04 PM
xtreme2001's Avatar
i only used 2 holes on each side of the block with stock mounts......i dont know what type mounts the umi member has but you should be fine
