.020 over?
Old Jul 8, 2012 | 10:48 PM
mtt14's Avatar
Default .020 over?
Pulled a spare lt1 that has been rebuilt before and has speed pro cast pistons from what im told they have 245np on the piston i believe. If i remember reading right they are lower compression than stock. So is there any forged. 020 over pistons that arent exspensive as hell just plan on a cam and 150 shot for now.
Old Jul 10, 2012 | 03:14 PM
ahritchie's Avatar
.020 over pistons? Kinda an oddball choice...the vast majority are .030 over or more.
Speed pro does not make any .020 cast piston...the only one they have is .030 over which is the standard overbore size. Are you absolutely sure they are .020 over?
http://www.jegs.com/p/Sealed-Power/S...44636/10002/-1
They do make a .020 over Hypereutectic piston however:
http://www.jegs.com/p/Sealed-Power/S...34022/10002/-1
Old Jul 10, 2012 | 03:39 PM
WS Sick's Avatar
You can call any Piston company and they have or will make about anything you want.
Old Jul 10, 2012 | 05:43 PM
jlpz's Avatar
Yes they do have .020 over pistons I had a set not too long ago that I had to return because they were suppose to ship me std. pistons..They were speedpro two valve notch cnc's pistons.
Old Jul 10, 2012 | 06:16 PM
mtt14's Avatar
Old Jul 10, 2012 | 06:18 PM
mtt14's Avatar
And yea id like to not have to bore just hone and get better pistons unless these are hypers and i could just run a thinner gasket and up my compression.
Old Jul 10, 2012 | 06:24 PM
96capricemgr's Avatar
So you would instead like to gamble a little on a shelf piston matching your existing bore?
Far as I know most reputable engine builders like to have pistons in hand before the final hone.
Old Jul 10, 2012 | 06:28 PM
Shownomercy's Avatar
Man-Crush Warning
Pull pistons, check bores, do hone job, gap rings accordingly. Run .020s and win?
 Michael S. Palmer
Old Jul 10, 2012 | 06:46 PM
lt1-xjs's Avatar
Sealed Power/Speed Pro L2256F20 is the forged unit.
Old Jul 10, 2012 | 10:50 PM
azlt's Avatar
those are the pistons ive got in my current engine, running great so far!
Old Jul 12, 2012 | 03:47 PM
Mystery Bird's Avatar
This is what's in my new build: http://www.jepistons.com/Products/138092.aspx
Old Jul 12, 2012 | 06:58 PM
Man-Crush Warning
Thats a heavy piston, but a nice one
Old Jul 12, 2012 | 07:13 PM
Probably because of the 5.7 rod. I offset them with a lighter pin.
Old Jul 14, 2012 | 10:47 AM
mtt14's Avatar
Thanks for the link xjs and mystery bird I was actually looking through your build trying to figure out whhat pistons you used, I like the je's but they're a little exspensive for my budget so I think ima get some speed pros and scat I beams.
Old Jul 14, 2012 | 11:44 AM
Man-Crush Warning
What crank throw and rod length? Look at SRP stuff.
Old Jul 14, 2012 | 04:25 PM
96TransAmboosted's Avatar
Try findimg a good ring for a .20 piston. Its not easy. I bought a block from a guy that had. 20 pistons wanted to re ring it and found its not common at all. Go. 30 and be done with it
Old Jul 14, 2012 | 04:42 PM
TwoFast4Lv's Avatar
Pfft!
I ran 4.020 Off the shelf SRP pistons to 700RWHP. standard .030 rings file fit
.020 gives you options the next time around AND a little extra wall
Old Jul 14, 2012 | 05:58 PM
gjohnsonws6's Avatar
.020" is not that uncommon, and good rings are very easy to find.
Old Jul 15, 2012 | 07:42 AM
Originally Posted by TwoFast4Lv
Pfft!
I felt the same way. With file fit rings it's no problem.
