LT1 fuel sending unit messing up
I replaced the fuel sending unit and fuel pump all at once when I first got this car. They were both bad and keeping the car from running (obviously). The new fuel sending unit worked fine.
I recently have been driving on the road and the fuel gauge jumps an awful lot while running and will even show all the way past the full line. From experience I know that this is caused by the fuel sending unit circuit not being completed. It always works however when I start the vehicle later.
The fuel pump still works when this happens.
Does anyone have an idea of what might be causing it? I don't know much about it so I thought maybe somebody had an idea of where I can start looking before I pull the fuel pump assembly back out.
super glue the needle to say full all the time if it bothers you.
OR
Print this and tape it to your dash:
Gauge Past full=full, on full=3/4full, 3/4full= half tank, half tank= 1/4tank , 1/4tank= 1/16 full , on/near E= your probably walking already
I've began treating half tank as empty
OR
OR
