What is this called?
Old Jul 19, 2012 | 11:47 AM
idabomb00's Avatar
Default What is this called?
I need to figure out what this is, can anybody identify it for me?
I need to replace a hose that goes to it but all I can find is universal fittings that don't have a bleeder screw.
Old Jul 19, 2012 | 11:52 AM
FormyLtX's Avatar
its the relief valve for the coolant system, somone correct if i'm wrong? i'm pretty sure of it.
Old Jul 19, 2012 | 12:01 PM
02v8ta's Avatar
:/ yes it's the bleeder valve.
You actually cut very carefully the metal crimps holding the bleeder to the hose and just re use the same bleeder with normal hose clamps.
Old Jul 19, 2012 | 12:02 PM
idabomb00's Avatar
Okay thanks for the help
Old Jul 19, 2012 | 12:09 PM
02v8ta's Avatar
The crimps probably won't hold after being cut in anyway. Use new hose clamps to re use the same bleeder valve.
Old Jul 19, 2012 | 01:53 PM
defaultexistence's Avatar
Your IAT is disconnected, no bueno
Old Jul 19, 2012 | 03:47 PM
idabomb00's Avatar
Wow, didn't realize that was disconnected. I took the intake off yesterday to locate the leak. Thanks for pointing that out.
Old Jul 19, 2012 | 04:54 PM
WS Sick's Avatar
Ive seen the bleeder in the help section with clamp on ends, you can also do a Throttle body bypass and cap of the third small line going to the "T". You'll need to cap off the other end as well.
Old Jul 22, 2012 | 06:17 PM
idabomb00's Avatar
I cut the crimped fitting off and used a regular clamp on the new hose and it works. Thanks for the help.
Old Jul 22, 2012 | 07:45 PM
02v8ta's Avatar
Glad it worked out!
Old Jul 24, 2012 | 08:35 PM
CAMJAG's Avatar
Is that one of those Tornado things in the intake boot?
Old Jul 24, 2012 | 08:38 PM
LT1's Avatar
LT1
lol it does look like a little fan on top of the intake elbo
