EGR and O2 sensor question
Old Jul 25, 2012 | 01:45 PM
CP-Z28's Avatar
Default EGR and O2 sensor question
I have a 97 camaro and I picked up some Pacesetter Longtubes without the EGR/AIR fittings. I have the block-off plates and the air pump is already removed. I also have the O2 extensions for the 2 front sensors and will have to remove the back set. I know I'll have to get the car tuned but what do I need to have it running correctly?
Old Jul 25, 2012 | 01:48 PM
02v8ta's Avatar
The block of plates installed, front O2 sensors hooked up minimum for it to run.
A tune to go along with all the work will resolve your check engine light and make it run great.
Old Jul 25, 2012 | 02:25 PM
CP-Z28's Avatar
Thanks for the info, I'll probably have to drive it for a day before it gets tuned and wanted to make sure it wouldn't run to terrible.
