Update on my 383 build
If nobody makes a point of how wildly incorrect you are someone else might actually listen to you, hell even now there are probably a few people who will listen to you because some dimwit at joebob's machine and bait shop told them similar things.
What is the compression on your beast of an engine? In the 10s"for pump gas friendliness"? Those of us who have been around awhile have seen a lot of this. It is sad how many "reputable" local shops completely destroy an LT1 build with weaker than stock cast cranks, stock or lower compression, ridiculously wide LSA on the low lift cam etc.
As stated, I'm building a DD. Yes I have other factors to consider than peak HP. I built for a flat torque curve, and I have to consider mpg, etc...
11:1 cr, and I haven't been bragging about my "beast" of a motor
I respect your experience and good advise, just not the poor tact. I went w/ a cast crank after a lot of consideration on my goals, how it will be driven, budget, and other components; all of which are factors on any build. I'm clear they're weaker than stock and forged counterparts. I can't speak of LT1 builds being "completely destroyed" by 'reputable' local shops, but I built around some of those qualities as necessary based on my goals. And I agree that LT1's are capable of a lot of power, if built right. Not sure what's wrong with not having a 10 sec car, though (since I'm not racing it)???
To the OP, make sure to set good goals, then build on that. For example, I didn't need "bigger is better" or a "race car" for my DD; just not practical and wouldn't perform right.
Is this what your looking for? Or just not a one piece in the 3.75" stroke...I can't find that on summit.
Ill go with the Melling oil pump so I know i have the oil volume/pressure it will need as well as a nice Moroso oil pan (7qt)
ANYWAY
Sent the cylinder heads out to AI today for the 190 cc treatment. I cant wait to get this thing back!
Some 355 with AI 200cc heads & a cam specd to em Will hand you your ***!!!!!!! I gave you the info to get a Scat forged crank
The machine shop can balance it to your bob weight & you can scream the bitch to 7grand if you want & Spray the **** out of it AS long as the other forged stuff will hold it Learn some Patience Grasshopper LoL
as well as destroying every part of the motor other than the intake and roller rockers! Block, heads, springs, cam all fucked from one oversight. I would have REALLY been pissed if I had some high dollar AI heads that got FUBAR! I would sell it and upgrade before it's too late.So, with my current setup, I did the opposite, got a very stout bottom end for room to grow for future upgrades (possibly nitrous
) such as ported aftermarket heads ect. with 500+ rwhp possible without worries. The Best V8 Stories One Small Block at Time
The LT4 was 10.8:1 STOCK specifically building an NA motor 11:1 is just another expression of ignorance.
The belief you needed stroke to have a torquey daily driver another expression of ignorance.
Mileage is not impacted anywhere near what people believe it will be,
Cam lift doesn't hurt manners for a "daily driver". For a DD stroker I would probably do upper 220s intake on a 110LSA lift somewhere up .580 or so, PTV should be checked but would not be an issue compression more like 11.5.
The cast cranks do not hold up though in RECENT YEARS we have seen more failures IMO it is a combination of a change in manufacturing making them weaker and power being easier to make. Thing is mediocre strokers with the cast Eagle cranks keep failing.
Stop and think about it, you can buy a Eagle cast crank for barely more than a local shop will charge to turn a stock crank undersized. That has to say something about how cheaply they are made.
Lots of guys get bent out of shape by my comments and a fair number of them later PM or email me and say something along the lines of "you were right about everything".
My car is not a racecar, favorite track is 150miles away, never been trailered to or from, lightest I ever weighed it at the track was 4155 with me. There is an Impala with the same engine setup I have but lighened and dialed in very well, that car I would call a racecar and it runs 10.9. I am giving up .6 and 6mph to keep my car more street friendly. The cam is more than I would want for a true all weather daily driver but opening up the LSA a little and losing maybe 10hp from that would be all it would take even in my heavy car.
I would assume it goes with their own rods. Google is your friend!
I also posted info on where to find a $500 forged crank. We are trying to help you just aren't very receptive.
For an NA or mild nitrous/boost 383 I think I would have a hard time finding a reason to use anything but a 6" rod. Longer rod makes the piston shorter and lighter which makes life easier on all the other parts. Now for heavy nitrous or boost I could see a shorter rod to keep the rings down further on the piston.
For some of us though, too much torque is not enough!
