LT1 waterpump issues, need a pro!
sorry for the long post, want to give as many details as I can!
OK so those of you who may have seen my past "cooling issues" threads will know what I've been dealing with.. I've spent wayyy too much time messing around with this, thinking I had a bad headgasket, ect... Basically my car is full bolt ons, with no tune yet. I'm waiting to put my headers & exhaust on, then I'm getting a tune for everything and lowering the fan temps.
Anyway, every since I got the car it runs hot. Everything is new or has been replaced - waterpump, radiator, 160* t-stat, the works. When the car is cruising fast and air is rushing in, it stays nice and cool, either at 1/2 or below on the temp gauge. But when city driving and sitting still it get's way up there, about 3/4 up nearly overheating before the fans finally kick on, and even then it stays real hot. Scaulding your hand if you pop the hood HOT. The system has been flushed completely, everything's new, bled a million times, all good in that department.
I was underneath the car yesterday and I haven't noticed it before but there was finally something to go off of, a small weep from the waterpump hole. It's a small drop every few seconds, but I think this what's been causing everything, I just haven't had a sign before now to figure it out. So does this mean the waterpump is bad 100%, or the seals are bad? Either way I know the pump needs to be replaced, just trying to figure out if THIS is indeed what is causing my cooling issues.
When I drive the car for a while then park it, I hear a loud bubbling of pressure trapped all inside the cooling system, and when I try and open the bleeder/s the coolant overflows out of the check resevoir. I have pressure tested the system a few days ago, pumped it up to 18psi and even went a little over, and there were absolutely no leaks, it held pressure for a good 10 minutes before I pulled the tester off.
My 383 car (which I don't drive anymore) has a Meziere HD waterpump installed, brand new pretty much never used. I'm thinking of putting it in this car to beef up the efficiency, my 383 car runs so cool you can beat the **** out of it for 2 hours pop the hood and everything is cool to the touch. Should I put the EWP in the 97, and will it fit? I've done a SLP lid conversion on the 97 so the radiator is tipped back a bit, would it still fit?
Even IF my WP wasn't bad since I drive this car a lot and we've been having 100+ degree days the entire summer here in WI I've been wanting to swap in that Meziere HD, that thing kicks ***.
I had to clearance the fan shroud on my 93 383 to fit the Meziere, but that was with the LT1 K&N intake setup with the stock radiator shroud in the stock position. with my SLP lid conversion, the radiator lays back a bit on the 97 so I'm wondering if the pump will work with this setup? If anyone has experience with this please let me know, I mean i guess worst case scenario I can pull the fans from the shroud, move them out of the way, and fix them to the radiator using spacers to get them out of the way of the Mezeire. But if I don't have to do that, let me know!
Sounds to me like you either have a dead fan or do not understand just how high the fan temps are. In stock form with a 180 stat the engine will run about 195 on the highway BUT the primary fan temp is over 220 and on the b-body at least the secondary is 242. With a 160 stat on the highway you will run about 175 which allows the fan temps to be brought way down to say 195 and 205.
Basicall what I am saying is first verify both fans work, then if you still think it is overheating get it reprogrammed, Is your pressure cap good?
The weeping waterpump will NOT cause overheating till it weeps a LONG time and you are low on coolant, certainly time to change it but to put a lower flowing electric on to "improve cooling" when flow is not the issue anyway would be just plain stupid.
the EWP, not going to debate about its cooling abilities over the mechanical type, but FWIW I have had one for 13 years with no issues in any driving condition includeing 115 degree outside desert temps. A EWP will elinimate the typical OEM WP leaking and pissing on opti issue.
you are running a 160 stat with a stock tune. not a good thing as you most likely are running rich now. get a tune, your headers will not influence that.
pull the connector on the front of the WP and both fans should come on..if not you have a fan problem so fix.
I suspect once you get a tune with lower fan on temps your cooling issues will go away...and your car will run better.
The right way to do it is to have the pcm reprogrammed for lower fan on temps, you are not introducing any new connections or failure points this way plus you get the added benefits of fueling and spark changes, tranny tweaks on an A4 cars. Plus with the pcm in control there is nothing for you to remember you just get in the car and drive.
1)A few things to check. Make sure that the gauge is actually reading right. Your dash gauge may be off.
2) check the cap on the radiator it may not be keeping the system at the proper pressure.
3) make sure you aren't running strait antifreeze. Antifreeze is not actually a coolant it is just to keep the system from freezing and lubricate the pump. You need to run at least a 50/50 of antifreeze and water. The water actually does the cooling. depending on your area you may want to 60/40 or what ever is recommended for your region.
Maybe I am just getting old but if I am sitting in traffic on a hot day the AC is on so the fans run for that.
I don't see the point in spending money to turn the fans on manually. The $70 Thunder asks for the kit can go a long ways towards reprogramming.
GTFO 93z383
