LT4 hot cam 1/4 mile times
Old 08-07-2012, 12:23 AM
daddyoisback's Avatar
12.325@113 ported stock heads stock internals, stock a4, 12 bolt 4:56 gears regular bolt-ons k&n headers etc. plus car was on a diet
Old 08-07-2012, 02:55 AM
Juicelt1z28's Avatar
@lt1-xjs lol i wasnt asking what they generally run,i just wanted to get some numbers from people who ran that cam on this forum. Im in the process of getting mine installed
Old 08-07-2012, 04:00 AM
lt1-xjs's Avatar
Keep in mind, to get the lower time slips the Hotcam likes the 6300-6400 rpm range. Good luck.
Old 08-07-2012, 05:55 AM
Rob
Rob's Avatar
Mine ran 12.4, my Dad's Comp TA ran 12.2, and Mom's Comp TA ran 12.5. That was well over 10 years ago.
Old 08-07-2012, 08:37 AM
@lt1-xjs thanks for the tip,im going to go to the shop today to check more into that! I have 1.6 rockers so i should be ok right?
Old 08-07-2012, 08:38 AM
@Rob Very Impressive Man!
Old 08-07-2012, 08:50 AM
96capricemgr's Avatar
So what I see here is someone asking a question trying to validate a decision he already made and then denying the answer he got. There are as many running high 12s to mid 13s as there are low 12s but you are PRETENDING low 12s is the norm.
You average things out and the answer Joe gave you is correct mid to high 12s is normal.
Hell several of the cars reported here are ported heads and then you have some getting into TH350 which is not a street car sort of thing.
Old 08-07-2012, 09:21 AM
@96capricemgr and your point being??? Yes im getting a lt4 hot cam installed and wanted to know what other people with the cam ran in the 1/4 so what! Also yes i am shocked to see low 13 second high 12 second times seeing as tho i run that without the cam,thats what the forum is for... Ask questions and be informed.
Old 08-07-2012, 09:27 AM
Also im not PRETENDING LOW 12s is the norm,i actually found it hard to believe hence the reason to me asking people who ACTUALLY OWN/OWNED lt4 hot cam cars
Old 08-07-2012, 09:48 AM
I usually see mid to low 12s on bolt on stalled hot cam cars
So which is it?
Old 08-07-2012, 10:34 AM
355z28's Avatar
I went 12.2@109 full weight, untouched heads and a pcmforless mail order tune.
The car was a 355, but being the motor was unballanced and using heavier pistons then stock there was no real gain...more likely a loss. I believe the car would've been in the elevens if it had a stock engine in it.
Austin
Old 08-07-2012, 12:17 PM
  #32
lt1-xjs's Avatar
Three hotcammed cars in one family, low to mid 12's. I'd call that the norm.
Old 08-07-2012, 12:21 PM
  #33
strasser_3's Avatar
There is so many more variables to these times other than the cam (car,weight,trans,driver,bolt ons,heads,ect) No car is going to be the same.
Old 08-07-2012, 03:40 PM
  #34
trilkb's Avatar
thats rediculous lol.
are these like 1.6-1.7 and below 60's or what? I should ditch my stupid cam for a hotcam, pick up speed, driveability and lower my 1/4 time lol....I dont see any loss! arnt they like 25 bucks now anywys(joke)?! Add a 75-100 shot and thats 11's.
is 6300-6400 a shift point or peak power? Meaning do you shift it at 6300 or do you shift it at 6500-6600?
You people are talking about the 219/228 @.050 492/492 with 1.5 rockers and 525/525 with 1.6 rockers..right?
is it bad that im seriously considering switching to a hotcam lol. This 226/232 .606/.603 108lsa cam just kinda sucks on a stock head engine.
Old 08-07-2012, 08:56 PM
  #35
joeZ96's Avatar
I was around 12.70's on motor, 11.20's on a 150 shot with stock heads. With LE2 heads and intake, I picked up close to half a second across the board.
Close, 218/228. The LS verson is 219/228.
Old 08-07-2012, 09:01 PM
  #36
and again several of the people reporting low 12s in this thread had ported heads.
Old 08-07-2012, 10:02 PM
  #37
Juicelt1's Avatar
Originally Posted by 96capricemgr
So which is it?
Again please help me understand why does any of this matter to you? Imo you have not been useful or helpful. In one of my last comments i stated that part of my reason for this post was to find out what people on ls1tech ran. When i google searched i found different links on several other forums with people stating mid to low 12 second times but imo was kind of too good to be true. Also even if i was looking for validation or what have you how does that pertain to you? Why do you care? Do you own a lt4 cammed car? Regardless of what point your trying to make its all irrelavant to this whole convo. Also if people have ported heads and are running 12s so what lol that should be a good thing right? Lol
Old 08-07-2012, 10:06 PM
  #38
Juicelt1's Avatar
And Again this post was intended for people that have or had a lt4 cam...im NOT looking for any estimates on what im gonna run i totally understand that there different variables in everybodies setup
Old 08-07-2012, 10:09 PM
  #39
Mike Morris's Avatar
Leatherneck from CamaroZ28.com went 12s with a hotcam easy on drag radials. Auto,stall and bolt ons with stock LT1 heads. I want to say he went low 12s at Cecil but I can't remember....
Old 08-07-2012, 10:30 PM
  #40
Juicelt1's Avatar
Thats were i will be running at. Cecil is a good track!
Quick Reply: LT4 hot cam 1/4 mile times
