need input on next step...give opinions!
So its a 226/232 .606/.603 108lsa cam, stock heads, stock bottom end, heads have never been off engine. Running patriot 8401 springs, trickflow pushrods, ls7 lifters and comp ultra pro mag 1.6 rockers. Exhaust is jet hot long tubes, hooker off road y and magnaflow catback. 3500 tci converter thats somehow still alive, 3.23 rear end, nt555r's out back. Also Ls1 SLP intake conversion. PCMforless tune. Suspension is LG motorsports coilovers, pavlock lca's, I thought a 2.0x 60' with 200lb/in rear springs was actually the only good thing about the outing..apart from not blowing my engine.
I retuned the car to shift at 6000-6100 and it completed the shift around 6200 or so. I just wanted to get some test runs to make sure it wasnt gonna blow up since it was my first cam install.
I for one think my MPH is low, the time isnt bad considering the mph, but I thought I should be atleast around 108 or so. DA corrected it wouldve been a 12.9 @ 107run I think, but lets face it, the time on the slip is the time you ran.
All of this brings me to the next step...
option 1 - I have a innovate mtx-l wideband, not installed yet, that I was told by one tuner reads off and isnt really a good measure of a/f, and told by another tuner "it reads good enough to get an idea of what you need to do". I think tuner 1 is right in saying if you dont know your exact a/f ratio, then its not really worth using as a measure. Dyno run is 100$ for 3 runs to get an a/f reading, then I can go to either tuner and get retuned and hope I pick up power. One tuner is 50$, one is ~300$
Option 2 - set shift points to 6500 again and go back to the track and see if I pick up 4mph. Getting retuned will probably set my shift points back to around 6500rpm as well. the 6000-6100 was just a test run
Option 3 - Drop to 1.5 rockers and see if anything better happens. I knew .606/.603 might not work going into this and was prepared to drop to 1.5's which puts lift at .568/.565, more in the stock lt1 head flow range.
Option 4 - Ditch the cam and go to a more friendly cam, honestly considering the hotcam, its going faster then my cam right now anyways lol.
option 5 - stop bitching and get the car to 60' under 2.0x lol.
anyways thanks for reading and thanks for your opinions. I'd like to see how other people would handle this.
I also find your lift funny in the face of a recent post about .530 being about max with reasonable seal clearance. https://ls1tech.com/forums/lt1-lt4-m...clearance.html
Your stall brand is at best hit and miss, pretty much considered junk for the 4L60E and your gear is hurting you too, never getting near the top of the powerband in third. If you couldn't hook though then I guess you need to start with chassis work before you worry about a decent stall, gears might help you hook a little though, I know that sounds odd but I think you will enjoy the car more with 3.73-4.10 anyway so do it.
The tune I would question and try and verify AFR.
If you can keep the cam under control I would try and stick with it.
Get a copy of Datamaster and a cable, it is free for the first 20 uses. If the airflow goes haywire at the upper rpms then that is an indication of float.
As far as valve float I dont know if Im experiencing any or not, the 8401's are a good spring. I couldnt run the 8501's due to install height, but LE said the 8401's would be fine when I told him about the issue. All that being said, I have a cable and tunerproRT, I may try to download datamaster this weekend and see whats up, its probably a better program, tunerpro is glichy. Ive datalogged a few times with it to check for knock and just see whats going on.
What airflow data do I look at to see if I have float? IF datamaster can datalog I may do a run or two this weekend and log it.
It also seems like upgrading gears is being said alot. The car did go through the traps at a pretty low rpm. The converter would lock up and the rpms would drop under 5500, maybe even to 4700-4900rpm I cant remember exactly.
The cam is aggressive, that much is forsure. Thats why Im wondering if I should just throw a hotcam in it and be on my way. It would eliminate some things on its own. Noone has really had luck with this cam, so its not something that suprises me.
Thank you for your input! Given me alot to think about.
Next time at the track maybe consider touching the brakes enough to activate the switch and keep the converter unlocked, it will probably go faster.
Far as what to look at in datamaster AFGS air flow grams per second is what you will look at.
I also dont know if there is a better spring that can be installed at stock height, It doesnt seem like its valve float but hell ive never experienced it either. another couple hundred of rpm may show different though.
I will check it out this weekend. I might get the wideband installed to finally to see if I can get an idea of what my a/f is at.
Second.. Yes, the high lift MIGHT be causing a slight power loss. The heads would have to be flowed to be sure. But like others have said, the high lift and larger cam might be causing float issues.
With having a stock bottom-end i wouldn't shift further than 6200. Any more is just asking for a spun bearing.
might be time for a rod upgrade or something else...
Far as what AFGS will do it it is floating you will just see the number go haywire.
I wouldnt be installed @ 1.800. I would be at 1.7x..whatever stock heads are. I forget the installed height with these springs on a stock head. IF I am seeing valve float perhaps LE can help me out with some springs or Im just going to switch cams to something more friendly, down time is not an issue and I think I could do it in a weekend this time around anyways. I'm starting to lose faith in this cam. The springs are 135 @ 1.800, With the shorter install height I think im closer to 142-145 or something. closed pressure is 375lbs. Ive been focusing more on the fact that they are not broken, since thats what 2 other people who ran this cam had problems with.
Saturday I will hopefully get the wideband bung welded in, and get a datamaster run to see whats going on. Then go from there.
Thinking the only solution is to cut both flange ends off the header and y pipe, then use a band clamp, or else the bung has to come back out, flange slid on and then bung rewelded lol. I wish I used my brain more often.
I ended up buying a band clamp and just cutting the flanges off, it actually is sealed better now too lol. The other side being flanged still makes up for this side, I dont think its going anywhere.
Anyways the wideband is on and calibrated finally. Its working. reads like 13.3-13.5 at idle, and drops to 11 or so driving part throttle...is that normal? I noticed on tunerproRT from an old datalog that I can read "Engine airflow" Id imagine this is the same thing Id read on datamaster right?
Maybe adding some fuel at part throttle would help with all my crappy driveability?
Thanks for the info nitrous2fast. - 14.5-15.1? thats not too lean? I thought you didnt want to be over 13.5 in any condition. I realize a/f ratios fluctuate but under any throttle % wouldnt you want it to not be lean?
I sent an email to see if a retune would address the part throttle A/F ratios or what. I might be able to get some figured out on my own if I keep searching on how to adjust the stuff. Getting this car to be more street friendly would ease any worries on selling it to a new owner, thats forsure. Plus the added power would be nice.
Also what amount of knock is an issue? I see like 3 to 6 sometimes, not often, mostly above 4000rpm. When I do the WOT run it will help to see whats going on up top, could be where the power is going too
Since the first month or so of the build, I think I have noticed a power loss. The car used to spin 2nd gear from a roll very easily, It barely spins on the 2nd gear shift, I think It did it at the track. 1st gear it blows the tires off but its got a 3500 stall, thats to be expected.
Is there any information that I should look for to see if my o2 sensors are bad? In a datalog are the left and right o2's supposed to be identical? On my log one can say 800 and one can say 300, then sometimes they flip flop with the other one reading higher...is that normal? Under throttle I think they read pretty much the same number but Im not 100% sure since I dont have the datalog infront of me.
If a wire got burnt some how wouldnt it cause alot more driveability issues?
IF the 02's are messed up, that would mean the plugs are fouled to right? The tune hasnt been changed, so all I can think of is the o2's and/or spark plugs are the issue?
I guess I need to check the o2 wires and make sure nothing got corroded. I might switch o2's and use extensions if something happened, I finally have the money to do it right.
Wish I knew a little more about this.
