rear suspension set up
Old Aug 10, 2012 | 08:04 PM
unioncarpenter84's Avatar
Default rear suspension set up
okay heres the problem im leaning towards the 315/35/17 mikey thomspon drag radials....
the problem tht is occuring is the car sags down tht the sixteen inch drag radials went inside the passenger side quarter with the 315s scared of the tire buckling the quarter......could this happen??
i got the kyb 8 way adjustables i have them set at four is there a way i can turn those so the doesnt pull the wheel
Old Aug 10, 2012 | 08:19 PM
96lt1m6's Avatar
are your springs bad? get a new pair of springs and or get drag bags for them
http://www.ebay.com/itm/Air-Lift-Air...8401bf&vxp=mtr
Old Aug 10, 2012 | 08:36 PM
there not tht old....heres how the car is lauching...1.61 sixty foot is the best
Attached Thumbnails rear suspension set up-376467_441744025848981_223916562_n.jpg
Old Aug 10, 2012 | 09:04 PM
96lt1m6's Avatar
i had 17x11 w/315s stock springs and the hose mod, these wheels have the 50mm offset so if you get them you should have no problem.
What springs do you have out back?
Old Aug 10, 2012 | 09:15 PM
duh's Avatar
duh
Personally, I'd crank them up to 8 and go. Just me though. My 315's rub if I don't have the bump stops in, but I'm on BMR drop springs. If I were at stick height, there's no clearence issue. Then again I don't know which offset I have either.
Old Aug 11, 2012 | 09:37 PM
stocks springs what brand 315s u have
Old Aug 11, 2012 | 09:39 PM
whats the hose mod?
Old Aug 11, 2012 | 09:41 PM
alright whats the eight mean stiffer?
Old Aug 11, 2012 | 10:17 PM
bufmatmuslepants's Avatar
your car is squating way too much, you want anti-squat, not squat on launching. My guess is that your LCAs are on a downward angle from back to front, where it should be about a 2 degree upward angle from back to front. A set of LCA relocation brackets could help your problem. Look at 96LT1M6's car as it is launching, the rear tires are sitting square in the wheel well, not tucked up in it. That is how it should look.
Old Aug 11, 2012 | 10:19 PM
so ur thinking of me buying the lca relocation bracets??how do i kno if its 2 degress
Old Aug 11, 2012 | 10:26 PM
Just look for a slightly upward slope. Put a level on it if you have to, but you want it to be slightly upward. The brackets are cheap.
Old Aug 11, 2012 | 10:29 PM
just thought they were for lowered cars...i got a kyb 8 way shocks there set on four
Old Aug 11, 2012 | 11:10 PM
not just for lowered cars, also for cars that have problems launching and have too much squat, like yours.
Old Aug 12, 2012 | 12:19 AM
duh's Avatar
duh
The 8 setting is stiffer both on compression and rebound. Get some lca relocation brackets on, set the shocks to 8 in the back and 0 on the front. That will allow the car to plant the rear tires and let the front rise to aide in that. If you have and adj tq arm, you can play with pinion angle as well. As pointed out, the body is squating too much in the rear. On a well set up car it will look as though the rear suspension doesn't move much if all. You can also ditch the front sway bar to aide in letting the front move a bit more. Hope this helps some.
Old Aug 12, 2012 | 02:01 AM
96lt1m6's Avatar
what rear springs do you have?
turn those shocks up a bit as stated.
the hose mod is where you remove the thick isolator from the top of the coil spring and replace it with 5/8'' heater hose... it generally gives 3/4'' drop in the rear.
when a car squats it becomes a huge waste of energy.. As MADMAN says only females SQUAT race cars launch.....
Old Aug 12, 2012 | 09:23 AM
alright sounds good...ill get some relocation brackets and change the shocks to 8 and see what happens.. i got a 1.61 sixty foot believe or not with this set up...with the brackets and changing the shock setting will the be harder on the rear end?
Old Aug 12, 2012 | 09:24 AM
i just got factory springs...i was looking at eibach drag launch springs those will prob help too..they come with one little air bag why wouldnt it come with two?
Old Aug 12, 2012 | 12:33 PM
96lt1m6's Avatar
The 1 bag aspect is common, it's for the right rear since that's the direction the car TQs to.
I would put the wheel and tire combo on the car just to see.... If it is just one side mainly the drivers side you most likely need an adjustable panhard rod.
Old Aug 12, 2012 | 12:38 PM
96lt1m6's Avatar
Oh and the 315s I had on were BFGs my TA has Nitto 315s on 17x11 zr1s and I also have the Eibach pro kit and the fender has been rolled
Old Aug 12, 2012 | 02:08 PM
duh's Avatar
duh
The rear end will see a bit more strain as you are actually putting the power through it as opposed to wasting the energy by moving the body around. It will see a bit more abuse, but I wouldn't worry too much about it.
