Battery Voltage
Does anyone have any idea why the gauge/computer is reading so low?
You really don't need that big of wire if you aren't running after market amps or electronics, but it doesn't hurt.
Simply checking the cables and connections for corrosion, and repairing/replacing bad connections will probably do the job.
Engine off, battery voltage: 12.5.
Engine on, immediately after start, battery voltage: 14.5
Voltage at back of alternator: 14.5
Voltage at distribution block: 14.5
Voltage on gauge: 13
Still seems that the gauge/computer consistently read about 1.5 lower than what is at the batter/alternator.
It sees 13 volts right now, because there is 14.5 at the battery. But after it warms up and the alternator is only putting out 13.5, I only see 11.5 to 12 at the computer via scan-tool. The gauge inside the car reads the same thing the scan-tool does.
I don't have access to a '95 service manual otherwise I could tell you where the C100 connector is.
http://shbox.com/1/1995_pcm3.jpg
http://shbox.com/1/harness.htm
Thx shoebox for ref.
As it happens, I think I still have the right side kick panel off as I was having to track down an intermittent short in the PCM fused wire. Turns out one of the fuel pump relay wires was rubbing up against some metal and shorting out.
http://shbox.com/1/1995_pcm_conn_b.jpg
