Cam with Stalling issues
to check out the tps and make sure it was .67 volt dc and it was so.......he also told me this......"you need to do is open the throttle blades using the throttle body set screw to allow the engine enough air to maintain the idle properly".
THanks,
Bryan
The T/A is getting a full on paint and body work this fall
These two pages are not great but they give you some idea of what to do. http://www.hashmarks.com/techtips/throttle_body_mod.htm
http://para.noid.org/~lj/PCM%20Tutor...litBLMinfo.htm
The stock TB has a bleed hole and the size of that hole is important enough that the L99 and LT1 got different sizes and the L99 used the same cam as the b-body LT1. You have increased displacement and cam size a LOT and you likely have an aftermarket TB that has no bleed hole atall and likely no longer seals the IAC circuit to the manifold and just dumps in the plenum. But even if you have a stock TB that hole would need to be enlarged for your application.
This is really basic stuff that a few of us have been posting info on for YEARS, the best link there was on it was.
http://members.***.net/gmarengo/Misc/Misc.htm
If someone could find it archived somewhere that would be very good for the community, it went more indepth into the hows and whys of the things the other two links touched on.
As far as the OP says about the converter I don't think we have the same problem.
junk don't buy this crap! I like to buy different parts to try out but this time it bit me in the ***..... strait out of the box it caused problems and I assumed it was the tune that was double checked and adjusted here's the link on that opti I bought from on ebay...
http://www.ebay.com/itm/NEW-DRAGON-F...d12907&vxp=mtr
http://www.ebay.com/itm/NEW-DRAGON-F...d12907&vxp=mtrLuckiely you have 60day return policy.
Ive been fortunate with chandlers opti, 5000 miles no problem, for weekend warrior.
I did do Locktite the rotor screws and siliconed outside case.
As with chandlers, some like them, some dont, my experence to date been good with no issues.
http://stores.ebay.com/Chandler-Moto...=p4634.c0.m322
BTW the only time I have ever had to drill holes in a LTx TB was back when I had a blower a nasty cam and no way to tune it
Sounds like yours was infact opti related. I just wanted to throw out that my pcmforless tune cam with the idle set to low for my particular cam. It sounded mean as hell, but it didnt like going into drive/reverse when hot.
