crank trigger ?
Old Aug 16, 2012 | 06:45 PM
edunegan's Avatar
Default crank trigger ?
Thinking of going to a crank trigger system instead of opti but can the stock computer still know what the ignition is doing
Old Aug 16, 2012 | 09:20 PM
fex77k's Avatar
No trying to run it with the stock computer will take some work. If you spend the money to get the crank trigger then you want to go aftermarket. ATI make some trick setups for their balancers too.
