Bolt-On Mods RPM Shift Points
Old Aug 20, 2012 | 09:38 PM
CamaroRacing12's Avatar
Originally Posted by bufmatmuslepants
As far as the fastest Bolton guys who frequently post here (me, camaroracing12, lt1 xjs etc) we all shift around 6000-6100. I don't think any of us have hit a dyno but we have all made a lot of track passes. Common knowledge is now that a full bolton lt1 shifting at 6000 rpm with good tires and a good driver WILL run mid to high 12s in under 2000 DA. If you can't run 12s in under 2000 DA with full boltons, your opti is broken.
pretty true statement.
6000rpms here. stock rockers and valvesprings
Old Aug 20, 2012 | 09:40 PM
we hit peak power around 5800rpms but shifting at 6000rpms nets better gains because it keeps you in the highest power band longer then shifting right at 5800rpms.
alot of people think its idiotic that i have my shift points set so high but they can't seem to understand that logic.
Old Aug 20, 2012 | 10:02 PM
96silverram's Avatar
1-2 = 6,300
2-3 = 6,200
3-4 = 6,100
6 spd with 4:11's, Full bolt-ons, Full weight WS6 T/A
Old Aug 20, 2012 | 10:09 PM
FAD2BLK93's Avatar
Full bolt on full weight 93 T/A, except headers. With 19" wheels 2.0 60ft 13.48@106.5. Shifting at 5800 shift completed at 6100. Now homported heads, .026 headgaskets, mid tubes, CC503, no stall yet. Best so far...2.05 60ft 12.86@110, shifting at 6000 completed shift at 6375 rpm. I hope this is what u were asking for?
Old Aug 20, 2012 | 11:33 PM
StraightTimeStirrups's Avatar
Yup! Exactly!
Old Aug 21, 2012 | 05:08 AM
bufmatmuslepants's Avatar
Why are your shifts so long?
Old Aug 21, 2012 | 05:40 AM
pancho toco loco's Avatar
Only thing I can think of is his shift light is set to come on at those rpms but the shift isn't completed till the rpms he has given?
Old Aug 21, 2012 | 07:03 AM
lt1-xjs's Avatar
Originally Posted by SS RRR
Where's your power peak?
5900-6000 rpm. It was ran to 6200 but flat lined from 6000 up.
Old Aug 21, 2012 | 07:23 AM
stumprrp's Avatar
My first camaro was a bolt on LT1 with 2.73 gears and a stock stall. No times, but i used to manually shift it as close to 6000 as i could. However, the car certainly starts to nose dive after 5600 IMO.
Old Aug 21, 2012 | 07:33 AM
Valve float, with new springs and rockers that would have gone away, I'm experiencing this now.
Old Aug 21, 2012 | 07:39 AM
SS RRR's Avatar
Village Troll
That's further up the RPM range than stock. I have no idea if a higher ratio rocker would move it up that much or not, but they do influence valve timing.
Old Aug 21, 2012 | 09:49 AM
  #32
FAD2BLK93's Avatar
My MSD shift light is set to come on at 6000 rpm. I record my runs with a MAC Taskmaster scanner. When i recall my runs the shift points are 3-400 rpm higher than my setpoint. And i know i shift most times Dead Nutz on time! So i can only conclude that the rpm still climbs inbetween the shifts, then gets dragged down on the next gear.
Old Aug 21, 2012 | 10:43 AM
  #33
lt1-xjs's Avatar
It seemed to work for me. I switched from a S/A 1.6 Promag to the NSA 1.7's adding the guide plates and chromoly pushrods. The power range seemed to creep alittle higher. I do dyno my car after I make changes and have like 6 times. Just the rocker swap netted a 10 rwhp 6 lb ft gain across the board on the same old springs.
Old Aug 21, 2012 | 11:06 AM
  #34
Wow 10rwhp from going from 1.6 to 1.7 rockers. That's a .1 and mph
Old Aug 21, 2012 | 12:33 PM
  #35
lt1-xjs's Avatar
It took me from a best of 12.97 to a 12.86 when I went to the track. That was 4 1/2 years ago when I put them on. I went a few years ago and ran the 12.82 with no changes, maybe alittle cooler.
