broke a valve spring last night.
#41
#42
Im fine with that and I agree that the valve is probably bent. But there is more to it then that. because how does a bend exhaust valve on the #5 cylinder take out the intake valves push rod on #5 cylinder? because it was the exhaust valve that broke the spring but it was the intake valve that broke the push rod. there has to be more damage then just a bent valve. I mean if it the exhaust valve was bent that bad that it could clip or jam the intake valve to the point it broke the intake valves push rod how did it hold air pressure? when we shut the compressor off it bleed of very very slowly I would think it would be a big rush of air if it was bent that badly.
I think a chunk of the valve or piston broke free and jammed the intake valve when it went to open and that's what broke the #5 cylinder intake valves push rod. But until I take it apart this is all conjecture.
#46
Update: broke a valve spring last night
I figured I would give you guys an update.
I pulled the motor and got the heads off and I have no damage. I am not sure why the spring broke nor the push rod on the next valve over. I took the heads to the machine shop and had them clean them up they said the valves were all good I had them install the beehive springs that comp recommends.
How often do you guys recommend I check my springs?
Also do you guys have any neat tricks for finding the push rod length?
#47
#48
Speedy I am running the stock rods and pistons. I have stock heads and valves. As far as I know this is the first time the heads have been machined. The block was decked. If You want I cant post a picture of the engine when it was just rebuilt with the 1# at top dead center. I also have a pic of the 5# cylinder.
#49
Your rocker travel should be exactly in the center of the valve tips and there should be absolutely no marks on the spring coils from bind.
#51
Yes the lifter must be solid. I can post some of reher-morrison's setup proceedure if you want. Looking through the thread it appears you had some kind of binding problem in the valvetrain geometry. You might need to check the installed height of the springs.
#53
OP
Comp bee hives (26915 or 26918) spec a installed height of 1.800". stock AL heads with stock length valves spec 1.700"-1.750" installed height. So if the spring pockets were not machined down your bee hives may be slightly tight. With a mild lift cam this really is not a problem but on high lift cams running 1:6 RR you could get close to coil bind but again the 502 is not a really high lift cam. You can certainly check with the shop that did your heads and ask what installed height they put the springs in.
on your PR length given the head & block work, cam and 1:6 RR your PR length likely needs to be slightly shorter than 7.200". If you have a solid lifter (or make one solid) and even use a light "test spring" you can buy thae mark the tip of valve and lash that one then rotate engine over by hand 2 times. if witness mark is slightly towards exhaust you need a shorter PR. Closer to intake a longer one (not likely). adjust the PR check tool to 7.150" and test again. Instead of doing the "turn the PR x thread deal" I measure the length of the PR with a caliper I have. Aftermarket PR come in lengths of .050 typically so that is why measure 7.150 then 7.100 if necessary. yeah you can order 7.121" or whatever length custom ones but you are not building a $100k race motor.
with the proper length PR rotate engine by hand and carefully look at spring when it is fully compressed to see if there is any contact between springs or RR is hitting retainer anywhere.
Also on lash make sure you are really at "zero" and you don't over tighten the lash. zero is when there is no more up/down PR movement, not when there is resistance spining the PR with your fingers. If your lash is to tight essentially colapseing the plunger in lifter...when you hit high RPM's you can easily bend PR or break springs that way.
