need more mph in the quarter
Old Sep 5, 2012 | 06:19 PM
  #61
unioncarpenter84's Avatar
Originally Posted by transbird95
Telling him his car is **** or junk wont help him fix it. I'd bet most of you had problems dialing in your rides. I know I have..... Grow up.
ya i forgot there always gotta be a few ppl in the crowd tht gotta try and be a hero!!!
Old Sep 5, 2012 | 06:21 PM
  #62
Originally Posted by bufmatmuslepants
Your car dude put it on the dyno it's $100 for 3 runs. What day and time and what track did you make your runs, we can at least calculate the da
it was august 30th it was at prp
Old Sep 5, 2012 | 06:25 PM
  #63
transbird95's Avatar
Take your time slip and go to dragtimes.com there is a density altitude calculator there just enter the date and track. It should say what time of the day you ran on the slip. Click on the closest hour they updated the site and it will tell you the DA.
Old Sep 5, 2012 | 06:31 PM
  #64
bufmatmuslepants's Avatar
Da was 2700, Corrected is 12.1 at 111, you still need to find out what's pulling so much timing. Might be time for a comression test or leakdown test also, the previous owner may have sold it knowing things were about to go south.
Old Sep 5, 2012 | 06:34 PM
  #65
is there any other signs besides doing those test like issues tht u can hear?
Old Sep 5, 2012 | 06:43 PM
  #66
Yea, can you hear any ticking or knocking? Is a header primary touching the k member or very close? It could be tapping it when under load causing a false knock. Is it smooth through the whole rpm range? What is your fuel pressure? When was the last time the plugs and wires were replaced and gapped? Since you are staying NA, put in NGK TR55s gapped around .035. It probably has TR6s or BRE7s which are colder meant for nitrous.
Old Sep 5, 2012 | 06:53 PM
  #67
it had tr6 i replaced them a few weeks ago gapped them around .040
Old Sep 5, 2012 | 06:54 PM
  #68
theres nothing touching i just checked all my slips to tht site im around 2 or 3 teeths off
Old Sep 5, 2012 | 06:55 PM
  #69
With more tr6s? How much did he spray that motor? Does it consume any oil?
Old Sep 5, 2012 | 06:58 PM
  #70
the motor was never sprayed at all he sold it right after it was built....it did till i put a catch can now hardly any
Old Sep 5, 2012 | 06:59 PM
  #71
yes with the tr6s
  #72
Did you have pcm4less tune it or did he? Does it have a 6al in it that is still maybe programmed to pull timing at WOT anticipating being sprayed?
Old Sep 5, 2012 | 07:04 PM
  #73
Someone else who is more familiar with nitrous motors, maybe gregrob, can chime in here about your plugs and tuning. The motor was clearly built for a HEAVY shot of nitrous, probably a 200 shot, I don't know how that would affect it NA though
Old Sep 5, 2012 | 07:18 PM
  #74
it doesnt have any ignition upgrade like msd or anything to pull timing....i had pcmforless tune it a few months back sent him all my info bout the car he tuned it for a na motor
Old Sep 5, 2012 | 07:45 PM
  #75
ya thts what i was told the car was made for is 200 shot im just scared of hurting the motor with nos could i get a system tht the nos will kick in second and third gear i wouldnt want it in first cuz my ten bolt
Old Sep 5, 2012 | 07:57 PM
  #76
Longbob's Avatar
Check your toe in at acceleration ride height. If you are not sure, put a floor jack under the front of the car and raise it about 3 inches. Your toe in should be about 1/16" to 1/8". This is a free mod and an important part of the chassis set up.
Old Sep 5, 2012 | 07:58 PM
  #77
sounds good ill have to check it out
Old Sep 5, 2012 | 09:29 PM
  #78
96capricemgr's Avatar
You do not need any ignition "upgrades" for NA. TR6 is a good place to start on plugs TR55 would likely be too hot if the pistons are flat top and this has some compression.
The toe thing is an interesting point but you have a lot of time and MPH to find before you look at something like that. If it is a street car have it aligned to something you like on the street, maybe you don't gain that last .05 at the track but most of us spend more time on the street than strip.
Is it pulling timing all the time or just occasionally? What are the AFGS doing? If they climb and then go haywire at the top of each gear that is often valve float.
How about the MAP reading VS BARO? You like them to be close at WOT, they will never be exact but withing say 1" or so. I think the MAP location leads to a little Bernoulli Effect because I have seen even monoblade equipped cars "pull vacuum" as seen by the MAP.
