Wheel Size Help
Old Sep 21, 2012 | 04:27 PM
RubberDucky21's Avatar
Default Wheel Size Help
I have a 96 z28. its dropped about 2". i have some 17s that a friend gave me and was wondering if there is any issue with putting these on? just bought her a couple days ago. dont know MUCH about suspension, shocks, effects of it being dropped, etc. yet. so any extra info is gladly accepted.
Old Sep 21, 2012 | 04:36 PM
warriorcustoms's Avatar
My 95 T/A has Eibach Pro kit springs & Speedlines off a 01 WS6 NO problems here & Im gettin 2 rims widened to 17x11 for 315s in the back Its all in the Backspacing & Offset IF those are wrong youll prolly rub or somethin IF someone that didnt know what theyre doin just cut or heated the springs Then get some Eibach or Strano springs & do it right!!! Eibach Sportlines need an adjustable panhard bar & relocation brackets for the rear control arms If I remember right!
Old Sep 21, 2012 | 05:07 PM
i know all the work that has been done (shocks, sway bars, suspension, and lowering kit) is all eibach/name brand stuff, so its all shop work. guy gave me receipts and everything. so they should work fine?
Old Sep 22, 2012 | 12:09 AM
FAD2BLK93's Avatar
I run the eibach sportlines, they are close to a 2.5 inch drop. I run 19x10 05 c5 rims with 285/35/19 in the rear. I had to grind the rolled lip back some and use a 1" spacer. Fronts are 275/45/18 and had no issues there. I am considering using a 1" spacer up front as well, to make it look right and maybe spread the footprint of the car to make it handle better. I think? I hope? Yes?
Old Sep 22, 2012 | 07:03 AM
VinR1's Avatar
Depending on width and offset of your wheels, you should be fine. May want an adjustable phb. Im lowered 2.5"
Old Sep 22, 2012 | 07:49 AM
FAD2BLK93's Avatar
Reason for adjustable bar please. What would i notice any different if i were to get one. What adjustments would i make with it.
Old Sep 22, 2012 | 10:51 AM
RamAir95TA's Avatar
When the suspension compresses the rear axle moves slightly laterally toward the passenger side. Shortening the PHR will keep the rear centered during normal ride height.
Old Sep 22, 2012 | 11:29 PM
FAD2BLK93's Avatar
Would widening the front tires with a 1" spacer on either side be of any benefit with the vette rims???
Old Sep 23, 2012 | 09:05 AM
VinR1's Avatar
What benefit are you looking for? I have a pair of 1" hubcentric spacer/adapters for $80 shipped
Old Sep 23, 2012 | 09:52 AM
RamAir95TA's Avatar
I am pretty sure such adapters are not legal for use at the strip.
Old Sep 24, 2012 | 12:18 PM
VinR1's Avatar
I must've missed where he said he's running the car at the strip - he did mention already having adapters on the rear of his car though...
