Mechanical Oil Guage
Old Apr 8, 2004 | 11:46 AM
GreekZ's Avatar
Default Mechanical Oil Guage
Anyone replace their stock oil guage with a mechanical unit?
My oil pressure switch is broke and figured it would be good to
switch over to mechanical one. If so, where can I buy the kit?
Thanks,
Andrew
Old Apr 13, 2004 | 11:38 AM
GreekZ's Avatar
Nobody? What I really want to do is plug the hole where the oil switch
screws in. I broke the switch when installing the longtubes and now oil
is leaking from there. Anyone know what size threaded bolt I can use?
Thanks,
Andrew
Old Apr 13, 2004 | 12:05 PM
bowtie9696's Avatar
You broke the oil pressure sending unit? How did you do that installing headers? Are you sure you're not talking about the coolant temp sensor?
Old Apr 14, 2004 | 05:33 PM
Slow TA's Avatar
Broke mine the other day taking out a spark plug
Old Apr 16, 2004 | 09:43 AM
The Big Show's Avatar
Thanks,
Andrew
You've got a 93 so the sending unit is above the oil filter where it's actually reading pressure before it hits the motor. If I were you, I would actually plug that port and use the port behind the intake so you get your reading from the motor. You can hook up a mechanical gauge to either port or just buy another sending unit from any local autoparts store.
