How much play...
Here's what I've always done:
Seat the converter fully into the transmission so it bottoms out on the pump. Then pull it out just enough to fit a 1/8" drill bit between the mounting flange and the flywheel. Whatever excess distance left over is the distance that needs to be shimmed.
The common spacing is 1/8" to 3/16" as mentioned, but I've always erred on the narrower side (1/8" without a problem).
If its that far out it can wear out the bump bushing So set the clearance at 1/8
