Gen V LT1
Old Oct 24, 2012 | 02:21 PM
Purple Poncho's Avatar
Default Gen V LT1
http://www.lsxtv.com/news/breaking-n...-block-reveal/
- Engine type: 90-degree V-8 with overhead valves; continuous VVT
- Displacement: 6.2L (376 cubic inches)
- Bore x Stroke (in / mm): 4.06 x 3.62 / 103.25 x 92
- Cylinder block: cast aluminum with nodular main caps
- Main bearing fasteners: six, including two cross-bolts per cap
- Crankshaft: forged steel
-Connecting rods: powder metal, 6.125 inches in length
-Pistons: eutectic aluminum alloy
- Compression ratio: 11.5:1
- Cylinder heads: 319-T7 cast aluminum with 59.02cc combustion chambers
- Valve angles (degrees): 12.5 intake, 12 exhaust
- Intake valves: 2.13 inches (54mm) hollow
- Exhaust valves: 1.59 inches (40.4mm) hollow sodium
- Camshaft: Hydraulic-type with tri-lobe for fuel-pump drive
- Camshaft lift: 0.551-inch (14mm) intake / 0.524-inch (13.3mm) exhaust
- Camshaft duration: 200-degrees intake / 207-degrees exhaust (at 0.050-inch)
- Lobe separation angle: 116.5 degrees
- Fuel delivery: direct injection
- Intake manifold: “runners in a box” design; composite construction
- Throttle: 87mm electronically controlled throttle body
- Ignition: 58X with individual coil-on-plug and iridium-tip spark plugs
- Horsepower / kW: 450 / 335 (estimated)
- Torque – lb.-ft. / Nm: 450 / 610 (estimated)
- Max. engine speed 6,600 rpm (fuel cutoff)
Old Oct 24, 2012 | 02:24 PM
jrwilliams95z28's Avatar
i like the shiny new LT1 badgeing haha hell yah!
Old Oct 24, 2012 | 02:46 PM
BigD383lt1's Avatar
I guess lt1 will be back on top... Maybe not mine but it will be a lt1!
Old Oct 24, 2012 | 03:05 PM
Platinum WS6's Avatar
I guess now it wont sound crazy to hear an LS guy say "Im swapping in a LT" =)
Old Oct 24, 2012 | 03:21 PM
Sticks n Stones's Avatar
Here's the article: http://wot.motortrend.com/next-gen-l...ch-280365.html
Sacrilege!!!!!!
Wonder how hard that swap is gonna be? Plug n play with existing computers? Probably have to get rid of the displacement on demand and variable valve timing though. Then you run into the always-present limitations of injector sizing that direct injection guys get saddled with.
I see the following happening:
$800 camshafts
$500 springs
$1,500 injectors
$1,200 intake manifold to make a swap work.
But all worth it if going forced induction, as that sweet forged bottom end should be holding ALOT of power! GT500 guys will be pissed.
Old Oct 24, 2012 | 03:37 PM
Bigg_Gunz's Avatar
It will be impossible. And I posted why earlier.
Old Oct 24, 2012 | 04:56 PM
Dave357LT1's Avatar
I'll wait 5-10 years till they are cheaper and people have figured out what works and what dosnt
Old Oct 24, 2012 | 06:40 PM
93Euphoria's Avatar
Anyone want to take a guess what company will be the best aftermarket performer for the new Gen V's? Id love to see AI give it a shot.
Old Oct 24, 2012 | 10:32 PM
SoxXpupPeT's Avatar
I cant Wait to see these going into 4th gens
Old Jan 9, 2013 | 06:01 PM
Leon Duhproblem's Avatar
Default 4th gen
you think those engines can go in the 4th gen camaros. i would love to put one in my 95 if i could
Old Jan 9, 2013 | 06:20 PM
bufmatmuslepants's Avatar
Someone please just lock this thread already.
Old Jan 9, 2013 | 10:42 PM
Geneticallybroke's Avatar
just got a huge rager!!
